Tutorial SPS - Sabertooth Packet Serial PID motor driver sketch w/SoftStart
Discussion in 'SimTools compatible interfaces' started by BlazinH, Nov 10, 2016.
  1. Pit
    30,510Coins
    you have to edit the sketch before uploading
  2. SilentChill
    20,601Coins
    Yes lol but where in the sketch
    edit: I found it however there are a lot, do i change them all ?
  3. Pit
    30,510Coins
    #ifdef SECOND_SERIAL
    mySerial.begin(115200);
    #endif
    to
    mySerial.begin(38400);
    #endif
  4. BlazinH
    16,691Coins
    I just sent you a PM with a new sketch to try with instructions how to change the sabertooths baud.
  5. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,447Coins
    @BlazinH, I only had a quick look so this isn't a comprehensive response but I notice the packet serial requires about 4bytes minimum per motor. At 115200 baud that's at least 1ms to send all the data to 3 motors without allowing for any processing in between.
    I would get rid of the ST[1] commands for motor 3 and just make it a two motor controller. That will give you a bit extra headroom.
    It also means that you don't want the PID loop running at its full speed. I note in SilentChill's screenshot Fpid is set to divide by 5 which is good - maybe even go divide 6 or more if I allowed it? If you run faster than that I expect it will be overrunning the tx buffer to the sabretooth.
    As for the baud rate to the sabretooth, this also means you want the fastest baud rate possible to get the commands flushed before the next time round the loop.
    You may also find that adding #pragma GCC optimize ("-fast") at the top of the code might help speed the code a bit (sometimes it can have negative effects though). Although the main limiting factor is the rate at which commands can be sent to the sabretooth this might at least ensure the rest of the code is as fast as possible.
  6. SilentChill
    20,601Coins
    @RufusDufus I have just tried from 5-10 Fpid and it didnt make any difference still each motor twitching in turn and then goes crazy when I try to move the sliders in simtools
  7. BlazinH
    16,691Coins
    Thanks for your sharing your insight @RufusDufus. I must not be figuring the baud rate correctly; 4bytes x 8 = 32 x 3 motors = 96 x 820 (fpid/5) = 78720?
    Also, I just added motor 3 for the hell of it but it has never been tested so removing it is a good idea.
    Btw, if the sabertooths tx buffer is overrun it will just ignore additional data. Sabertooths can handle up to 2000 updates per second though.
  8. BlazinH
    16,691Coins
    Probably don't want to use larger than Fpid /6. That will give 410 motor updates per second and I don't think less than that would be good. You could try using 4 too just for kicks.
    CORRECTION: I was incorrectly thinking in binary terms. Fpid /10 = 410 updates per second and Fpid /6 = 683.
  9. RufusDufus
    Adelaide Australia
    16,447Coins
    There are 10bits for a serial byte at the hardware level (includes the start and stop bit)
    so that is 1/115200 * 10 * 4 * 3 for three motors with 4byte packets = 1.04ms assuming the bytes are sent without any interbyte delay which might be optimistic for softwareserial?
    The PID loop is about 4000Hz at full speed from memory so Fpid/5 = 1.25ms round loop assuming nothing else slows it down.
  10. Pit
    30,510Coins
    @RufusDufus today I tested again the UNO with the latest sketch from @BlazinH and I can confirm that 1ms packet rate works flawlessly on the UNO. Maybe there was a bug earlier when testing different betas so at that time I came to this conclusion.
  11. BlazinH
    16,691Coins
    Updated sketch posted.
  12. SilentChill
    20,601Coins
    Quick update, I have been using the latest sketch now for a few weeks and it is working had to set Fpid 4 to get rid of an annoying twitching that was going on but other than that it works great.
    Big thanks to @BlazinH for all your hard work making this and helping me set everything up and @RufusDufus for his amazing SMC3 :)
    Think this should possibly get a sticky @Historiker @value1 ??
  13. Historiker
    9,205Coins
    Agreed and done.
  14. BlazinH
    16,691Coins
    UPDATE: This sketch is further optimized for speed and can now use an Fpid setting of 1. If you experience motor twitching or issues at Fpid = 1 then try increasing it.
    Btw, added a SOFT START motor routine too so I need some testers to let me know if it needs any tweaking. At the top of the sketch look for
    //SET SOFTSTART SPEED
    const int SSloop = 8;
    I estimate SSloop = 8 to be around 2 seconds to achieve full motor power. Increasing SSloop will slow it down more and decreasing it will speed it up.
  15. SilentChill
    20,601Coins
    Is this so that the when it starts up it moves slowly into position ?
  16. BlazinH
    16,691Coins
    Yes, on initial start.
  17. MajorClod
    MajorClod New Member
    - 14Coins
    Set this up on my test bench with a new Arduino and 2x32 today. Everything went smoothly. Looking forward to trying it with some bigger DC motors on the weekend. Great work guys.
  18. baykah
    baykah Active Member
    Toulouse - France
    414Coins
    Great work !, working great with my 2x32
  19. MWB
    MWB Drive it like you stole it!!
    Commissioning Engineer
    U.K.
    424Coins
    2DOF, DC motor, Arduino, Motion platform, 4DOF, 6DOF
    Just ordered the 2x60 Sabertooth, so this is really helpful! Thanks :thumbs
  20. MajorClod
    - 14Coins
    FYI - if using the new Simtools 2.0, your interface output should be: [A<Axis1a>][B<Axis2a>][C<Axis3a>]
    Note the Axis1a not just Axis1
    Might be worth updating the original post.
