My 2Dof for FSX
Discussion in 'Flight Simulator X' started by Farfred, Oct 16, 2015.
  1. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    Thanks for letting me know on tunning...
    I am getting to know how simtools work.. I reset the max/min with capture, and it is so much better now..
    Uhm.. I am a bit confused with the axis direction settings.. Does it should be opposite direction? Roll/sway, pitch/heave.. And can I get your settings as a reference??
    153,770Coins
    +11,149 / 57 / -2
    Which way an axis moves is determined by the Dir box being checked orange or not, So in the picture the sim would roll one way and if you unchecked the orange box and check the top black box so it turned orange then the sim would roll the opposite way.
    It is far better to take your time and learn how to create a motion profile for your sim, as all sims are different and the settings someone else uses won't get the best out of your rig. It takes time but there is the SimTools documentation, the SimTool Settings Tips & Tricks and plenty of good advice from members to help you figure it all out:
    http://www.xsimulator.net/simtools-complete-documentation/
    http://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
  3. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    I read this post and... I think it will be even more complicated set-up and adapt the SimTools software to my 3 dof motion system to "fly" with Flight Simulator X...!
  4. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    as I think, roll and pitch are related to attitude, and sway and heave are related to acceleration.. so what I am wondering is.. should "sway" be the opposite to "roll"?? and heave/pitch..
    153,770Coins
    +11,149 / 57 / -2
    Yes sway leans away from a corner and roll should be opposite.
  6. jeyf
    jeyf New Member Gold Contributor
    345Coins
    bonjour
    je viens de realiser le 2DOF comme vous avec FSX je compte passer en 6DOF avec effet de levier en gardant ce type de moteurs.. je me susi familiarisé avec simtool qui est plus intuitif que x-sim qui pour moi ne fonctionait pas ( xpid n'etait pas reconnu ... )
    je suis donc actuellement avec ARDUINO et motomonster
    j'ai deux questions le code est il le meme pour les sabertooth et la motomonster en 2DOF
    je n'ai pas trouver ou telecharger le fameux code 4DOF dont vous parlez plus haut ... existe il un code 6DOF ?
    153,770Coins
    +11,149 / 57 / -2
    Google Translate -
    Hello I just realized the 2DOF like you with FSX I intend to pass in 6DOF with leverage while keeping this type of engines .. I susi familiar with simtool which is more intuitive than x-sim which for me did not work (xpid n I am now with ARDUINO and motomonsterj'ai two questions the code is it the same for the sabertooth and the motomonster in 2DOFje did not find or download the famous code 4DOF of which you speak above ... is there a 6DOF code?
    You can duel post in French on the main threads as long as you also include an English translation, that will aid you in getting assistance from members.
    We have bi-lingual speakers from many different language groups so if Google Translate really messes it up they can help clarify what was intended.
    Please start your own project thread here and post questions to it rather than on the build thread of other members: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
  8. Tomsix
    Tomsix Member
    Németország
    324Coins
    Hi can i ask how is your wireing diagram for the Pc power supply? I see more than just 1 wire into one connection.
