Yet another OSW build
Discussion in 'Direct Drive Wheels' started by TOPMO3, Nov 19, 2016.
  1. TOPMO3
    TOPMO3 Active Member
    Russia
    896Coins
    • Like Like x 14
  2. obobo
    obobo Active Member
    1,323Coins
    impressive job, and very accurate
  3. RacingMat
    21,058Coins
    @TOPMO3 : nice wiring!
    nice magnet paddles! you have designed the paddles yourself?
  4. Nick Moxley
    Nice build....NO QR ?
  5. TOPMO3
    Russia
    896Coins
    Thanks guys!
    @RacingMat , yes its my design, 1st version. Fortunatly for me they are comfortable enough, but I'm going to change design a little bit for more tuning options :)
    @Nick Moxley , no QR yet. I have only one rim, so no need for QR (at least for now ))
  6. RacingMat
    21,058Coins
    Cool! What is the cutting technic? and the material please ?
  7. TOPMO3
    Russia
    896Coins
    Its laser cutted 3mm acrylic. Its not so nice as carbon of course, but does job well and very cheep - both paddles cost me ~ $10 :)
    • Like Like x 5
  8. bruce stephen
    general contractor
    michigan
    9,115Coins
    Nice rim....are the files for this available?
  9. TOPMO3
    Russia
    896Coins
    sure :)
    construction is simple
    • Winner Winner x 6
  10. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    nice one @TOPMO3 . i have a cnc plasma coming monday. ill knock up a set when its up and running
  11. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,767Coins
    DC motor, Arduino
    Beau travail et merci pour les fichiers.
    Nice work and thanks for the files.
  12. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Thank you for sharing these drawings.
    What kind of magnets have you used?
    I guess you have just glue them to the top part?
  13. TOPMO3
    Russia
    896Coins
    @prodigy
    yes, I glue them to the top part. In fact, there are 3 pieces of magnets - 2 of them glued to the top and one is between those 2 and a bolt. Its hard to take good picture but I tried
    Last time I used neodim magnets, 2 on top - 15x15x5 with 5.31 kg force and 1 in between - 15x8x5 with 3.41 kg force.
    They are bigger than in OP
    I know 3 pieces of magnets is not so optimal design and may be in next version I switch to standart 2 pieces
  14. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    @TOPMO3 .have you copied these from somewhere. i get my ascher paddles tomorrow so will see how the magnets are on those
  15. TOPMO3
    Russia
    896Coins
    Its my own design (not very optimal) if you mean this.
    I believe Martin's and probably every other shifters use two magnets - one on the top and second on a paddle itself, so magnets interacts with each other. In my version magnet interact with bolt on a paddle.
  16. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    yes i can see it now. the first picture threw me as i wasn't sure what i was looking at
  17. insanegr
    insanegr !N$@n€
    Athens
    16,724Coins
  18. TOPMO3
    Russia
    896Coins
  19. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    very nice thumbs up !
