Wiper Motor Models
Discussion in 'New users start here - FAQ' started by ajbrass, Nov 21, 2016.
  1. ajbrass
    ajbrass New Member
    Burntwood
    206Coins
    HI All,
    Just starting my build and have purchased some used wiper motors from eBay.
    Bosch 0 390 241 358, from a Rover 75/ZT, so whilst not a truck or very large car its a reasonable sized saloon and I thought Bosch might be a reasonable build quality.
    Anyway when modding the ground isolation, it became apparent that the magnets on the stator of one of the motors were basically shattered into about 6 pieces. I have removed the loose pieces (see photo) and the motor does still run but it is noisy and I guess will make less power or speed, so needs replacing.
    I also noticed that the helical gear in these motors are plastic, (not sure if that is important) and the output shaft has a fine spline which isn't ideal to interface with for something homebuilt.
    So before I go and buy a replacement of the same type, I was wondering if anyone has a go to list for a model of specify wiper motor or a specific car (sold in the UK preferably), that uses good wiper motors.
    Andrew
  2. obobo
    obobo Active Member
    1,323Coins
    don't forget to remove the grounded wire inside the motor to prevent short circuit
  3. Blame73
    Blame73 Well-Known Member
    8,303Coins
    My wiper motors are almost identical to yours, I think almost all are.
    I use motors from VW/Audi (this is the last one I bought: link)
    The output shaft is not the best to deal with, so I started using glue for metals
  4. ajbrass
    ajbrass New Member
    Burntwood
    206Coins
    Blame37, how did you use the glue for metals? I was thinking of pitting a flat on the shaft.
  5. ajbrass
    ajbrass New Member
    Burntwood
    206Coins
    Yes, that that is why I had the motors apart. I've checked and the case now floats. Any idea what happens if you connect both high and low speed brushes?
  6. obobo
    obobo Active Member
    1,323Coins
    no idea at all
  7. ajbrass
    ajbrass New Member
    Burntwood
    206Coins
    When I get my replacement I will give it a try on the old scrap one.
  8. Blame73
    8,303Coins
    This is how I'm making my shafts, and where I put glue for metals
  9. obobo
    obobo Active Member
    1,323Coins
    I am not sure that with the length, it is very solid
    When the simulator moves quickly, it may move
  10. Blame73
    8,303Coins
    No, it doesn't. It's not that long, maybe 4cm., it's just unscrewed in the pic.
    I have got it two years now and it doesn't move
  11. obobo
    obobo Active Member
    1,323Coins
    The fact that it is unscrewed gives this impression of fragility
  12. ajbrass
    ajbrass New Member
    Burntwood
    206Coins
    I guess you mean thread lock when you say glue. Something like Loctite 272 can hold 17ftlb of torque. I think the wiper motors do about 13ftlb on high speed, 17 on low speed, so with some tightening onto the shoulder on the shaft I can see how it would hold. Think i might put a flat on the shaft also though.
  13. Blame73
    8,303Coins
  14. xiejin
    xiejin New Member
    CHAINA
    94Coins
  15. Sinan Keskin
    Sinan Keskin Sinan Keskin
    journalist
    Turkey
    171Coins
    2DOF, DC motor, SimAxe, Arduino, Motion platform
    this is my wiper motors, 12v and big one 24volt
