Delay between input and output in simtools
Discussion in 'SimTools DIY Version' started by sww, Nov 23, 2016.
  1. sww
    sww New Member
    Austria
    256Coins
    Simtools does have a delay of 25 seconds and up between the input and the output data in my system. No matter weather I am playing a game or output testing in GameEngine. I have tried to play the game on a seperate computer with GameManager and one withGameEngine, as well but it still does not work properly.
    Any Ideas what the problem could be?
    153,697Coins
  3. sww
    sww New Member
    Austria
    256Coins
    It is with SketchUp. The model looks pretty complex, but is not in reality because most objets aren't calculated by sketchyphysics. It works just fine with the Sketchyphysics controls in SketchUp.
    Do you think this could be the reason though? If so, the model complexity is not the problem for Sketchyphysics but for SimTools.
    153,697Coins
    It is not SimTools, it is the model causing the delay via SketchyPhysics.
  5. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    2DOF, AC motor, Arduino
    Hello
    I never used it with SketchUp, but seeing the image of your SketchUp mockup, I see a shadow.
    In my opinion, it must consume unnecessary computing time. Try to delete it and make a comparison
    By simplifying the SketchUp file step by step, there may be a way to decrease the offset time
    SketchUp and Simtools are on the same PC or PC?
    I take advantage of your post to ask the community SimTools, if the same type of animation is possible under FreeCAD 1.6 instead of SketchUp?
    Has anyone worked in that direction?
    About which version of SketchUp do you use, the bridled but free version after the 30 days?
    Bonjour
    Je n’ai jamais utilisé avec SketchUp , mais en voyant l’image de votre maquette SketchUp, je vois une ombre.
    A mon avis, elle doit consommer du temps de calcul inutile. Essayer de la supprimer et faites une comparaison
    En simplifiant par étape le fichier SketchUp, il y aura peut-être moyen de baisser le temps de décalage
    SketchUp et Simtools sont sur le même PC ou sur PC?
    Je profite de votre post pour demander à la communauté SimTools , si le même type d’animation est possible sous FreeCAD 1.6 au lieu de SketchUp ?
    Quelqu’un a –t-il travaillé dans ce sens ?
    A propos quelle version de SketchUp utilisez-vous, la version bridée mais gratuite après les 30 jours ?
  6. Pit
    30,510Coins
    no offend and imho this model does not meet your expectations of a working simulator...JFI
  7. sww
    sww New Member
    Austria
    256Coins
    As I already mentioned: If the model is controlled by sketchyphysics slides it works perfectly and has no delay. If it is controlled by SimTools it does have delay. This means the problem is not in SketchUp and sketchyphysics.
    I have now tried to reduce the model complexity by turning off unnecessary features, like shadows, and deleting unessential stuff, like the seat and other things. But the delay does not get less.
    153,697Coins
  9. sww
    sww New Member
    Austria
    256Coins
    I have tried it with your model and settings, which resulted in a delay time of well over a minute. This is even higher than the delay with my model was.
    153,697Coins
  11. sww
    sww New Member
    Austria
    256Coins
    I have reinstalled Simtools and SketchUp. The delay time is shorter now for some reason, with about 15-30 seconds insted of 60 - 90 seconds. The serial output reacts instantly, though.
    153,697Coins
    Did you delete the C:\Users\Your_User_Name\AppData\Roaming\SketchUp folder before re-installing and can you please confirm you are only using the supplied tutorial files and model?
  13. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    @noorbeast . i dont suppose you know the traction loss set up in that video do you. it looks like it works really well. i cant find how i had mine set up and now im back to bouncing left and right again
    153,697Coins
  15. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    Thanks @noorbeast. ill have another go at that tomorrow.
