Dirt Rally in VR
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by Brett Horton, Nov 27, 2016.
  1. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    Morning guys!
    Trying to get Dirt Rally going on my new rig....
    Patched fine, and Sim Tools sees the game running, but no live telemetry to Tuning center.
    What am I doing wrong?
  2. f1iceman
    - 87Coins
    My first check would be does it work with motion on other games still.
  3. Brett Horton
    Tampa FL
    118Coins
    Yes works fine with other games, this is the first time I have patched Dirt Rally....
    152,571Coins
    +11,087 / 56 / -2
    Did you run it first, before patching it, and is your system 32 or 64bit?
  5. Brett Horton
    Tampa FL
    118Coins
    yes has been run many times and 64 bit
  6. f1iceman
    - 87Coins
    have you tried running with admin
  7. Brett Horton
    Tampa FL
    118Coins
    yep tried that also..... No Joy
  8. f1iceman
    - 87Coins
    i would uninstall the patch and try again but open plugin updater with admin when patching.
    also can you get into the tunning setting and capture the game and drive.?
    or is it in the list of games in the tunning setting capture section.
    also have you checked you axis setting are setup could be that too.
    ive had things like this but soon as you capture it works, if all the signs are there.
  9. Brett Horton
    Tampa FL
    118Coins
    Rgr thanks,
    Yes the game is running as far as the Game Engine is concerned as it does come up when you run Rally.
    The Tuning Center does populate the min max default settings, but no live data is being seen in the top green box.
    All my other games are working properly as expected, just this one so far.
    Thanks for everyone's help!
  10. f1iceman
    - 87Coins
    run the capture in the setting see what happens after you save it remember drive without crashing if you can and dont forget to do that save then stop capture., also check the axis is setup by selecting the game and saving it.
    sounds like its there just a few silly issues that does sound like ive had before where you just check the axis settings and then run the capture drive and then save it. i shut it down then restart it all and it has always worked for me.
  11. Brett Horton
    Tampa FL
    118Coins
    Rgr,
    I will try tomorrow.
    Thanks!
  12. f1iceman
    - 87Coins
    help if we can see how you go n update us all.
    maybe screen shots next of it all if don't work ok.
  13. noorbeast
    152,571Coins
    +11,087 / 56 / -2
    With 64bit did you patch it to the /Documents/Games folder?
  14. Brett Horton
    Tampa FL
    118Coins
    yes documents/my games/dirt rally vr (I think that is the exact path, I am at work)
    I also have a Dirt Rally (not vr) but the game is not recognized at all by sim tools (obviously as I am running vr)
  15. Brett Horton
    Tampa FL
    118Coins
    Alrighty.... So.... I am a dumb ass.... but still not working lol
    I DID NOT have the axis assignments setup for Dirt rally specifically... I fixed that KNOWING that would be the issue. Still no joy.
    See below a couple screen shots, when the game is running you can clearly see sim tools sees it and populates the tuning center with game limits but no live input. I have tried capturing limits, but did not make a difference. Dirt 1.jpg Dirt 2.jpg Dirt 3.jpg
  16. Brett Horton
    Tampa FL
    118Coins
    Here is the save path
  17. Blame73
    Blame73 Well-Known Member
    8,305Coins
    Nope, it's surely not seeing the game, the correct folder is (in my case) C:\Documents\My Games\DiRT Rally
    not DiRT Rally VR
    Remove the patch and patch it again
  18. Brett Horton
    Tampa FL
    118Coins
    Are you running VR?
  19. Blame73
    8,305Coins
    Yes
  20. Brett Horton
    Tampa FL
    118Coins
    yep that got it going! My first problem was I did not have the axis setup specifically for Dirt, then was patching to the VR folder. Thanks for your help!
