New French with a question
Discussion in 'New users start here - FAQ' started by Dronneau.Y, Aug 23, 2015.
  1. Dronneau.Y
    Dronneau.Y Member Gold Contributor
    france
    65Coins
    I threw myself into making a 2Dof for now still at the experimental stage.
    I started with a XSIM K8055 and configuration, and decided to move on
    arduino and Simtools.
    After installing Simtools, I get to a résulat Output in Testing, but no game with LFS data set will appear in Tuning Center (cf. Attached). Can anyone guide me?
    thank you
    154,028Coins
    +11,165 / 57 / -2
  3. Dronneau.Y
    france
    65Coins
    OK! I'm going to try. Even with version 1.3?
    154,028Coins
    +11,165 / 57 / -2
    Yes, @yobuddy has advised the language bug will be fixed in the next version.
  5. yobuddy
    51,567Coins
    @Dronneau.Y, do you have a interface setup for output?
    can you post screenshots of your Game Engine settings?
  6. Dronneau.Y
    france
    65Coins
    Here, thank you!
  7. Dronneau.Y
    france
    65Coins
    LocaleEmulator did not change my problem!
    I noticed with NetBalancer that Live for Speed will open some ports.
    Is Normal?
    154,028Coins
    +11,165 / 57 / -2
    I am not sure what code you are using to interface with SimTools and some further details would help: http://www.xsimulator.net/community/faq/arduino-code-for-use-with-various-hardware-and-simtools.31/
    The total for each Axis should be 100%, not 100% per DOF: http://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    The official SimTools documentation is here: http://www.xsimulator.net/simtools-complete-documentation/
    Download @Pit's handy guide to setting up SimTools, installing plugins, setting comport for Arduino and motion profile making: http://www.xsimulator.net/community...t-up-simtools-arduino-and-write-profiles.123/
  9. Pit
    30,510Coins
    Which Arduino Code are you using?
  10. Dronneau.Y
    france
    65Coins
    Yes, I put 100% axes because I had no result, but I understand the need to allocate 100% between all axes.
    In terms of the code is that of Wanegain v1.23
    154,028Coins
    +11,165 / 57 / -2
  12. Dronneau.Y
    france
    65Coins
    Yes I do. It works in Testing Output
  13. noorbeast
    154,028Coins
    +11,165 / 57 / -2
    So, is the game patched OK and does the Game Manager turn blue indicating the game is running: http://www.xsimulator.net/simtools-game-manager/
    And since you changed the language settings of the computer to US do you now see a decimal point instead of a comma in the Tuning Center numbers?
  14. Dronneau.Y
    france
    65Coins
    I just found the file CFG.txt Live for Speed was the Wrong.
    Thank you for your support
    cf. attached files
  15. Dronneau.Y
    france
    65Coins
    I recently started using Arduino + SimTools and I would like to reuse my old K8055 card, but I do not quite understand what to do for the installation to succeed!
  16. yobuddy
    51,567Coins
    Did you path the game, or did you patch the game and then change the ip address of game engine in game manager?
    I ask because I know LFS works as its my main testing game.
  17. Pit
    30,510Coins
    hmm, I wonder why you have answered here because I know that you know that this is an old thread...?
  18. yobuddy
    51,567Coins
    @Pit,
    lol, you are right. o_O
    I've been up half the night working toward the release of 2.0 :cheers.
  19. Pit
    30,510Coins
    No worries mate please take care and take the time you need for the release :)
