Movements don't suit to data
Discussion in 'SimTools DIY Version' started by JohannesNicklas, Dec 1, 2016.
  1. JohannesNicklas
    JohannesNicklas New Member
    156Coins
    I followed the instructions in the Documentation section. Now the problem is, movements of the 4DOF model dont suit to the acting forces form the game (LFS). But when i move the model manually through the output testing, everything works how it should. Also when turning off the mini servos move to an bad position, how can i solve this?
    152,694Coins
    +11,090 / 56 / -2
    It would help if you posted pictures of all of your settings.
  3. JohannesNicklas
    156Coins
    Yes of course, here are the pictures, the rest is on the default settings.
    152,694Coins
    +11,090 / 56 / -2
    What code and hardware are you using?
    The Interface Settings look to be like some mixture between JRKs and Arduino settings, with unneeded options.
  5. JohannesNicklas
    156Coins
  6. yobuddy
    51,254Coins
    Can we get a pic of the sim, the axis assignments setting seems strange.
    152,694Coins
    +11,090 / 56 / -2
    I am presuming these from @eaorobbie: https://www.xsimulator.net/community/threads/problem-with-pololu-micro-maestro.4920/#post-47686
    You have too high an Axel Assignment percentage total: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    Axis DIR settings should have movement following these conventions: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    What path did you use to patch LFS?
    Does Game Manager turn blue and say Connected when LFS is running?
    Did you run LFS and do a couple of laps before patching? If not then unpatch, run some laps and then repatch.
  8. yobuddy
    51,254Coins
    Your axis assignments don't make a lot of sense to me.
    But I would have to see the sim to tell you for sure.
  9. JohannesNicklas
    156Coins
    Thanks for your tips:)
    I will try them tomorrow, when i come to the highschool again.
    @noorbeast: when i run LFS, the game manager turns blue and says game connected, the patching path is C:\LFS.
    @yobuddy , these are the pictures of the model:
  10. yobuddy
    51,254Coins
    @JohannesNicklas
    That model does not look very stable, does it stand pretty stiff when not in use?
    thx for the pics buddy.
  11. JohannesNicklas
    156Coins
    Sorry guys, i had a little bit stress over the last weeks and so no time.
    @yobuddy The model stands not quite stiff, but its only for tests because we have to make a hexapod too.
    I was setting up the PC newly and installed all softwares. I confused roll/pitch with surge/sway. Now the axis can be driven seperately and heave and yaw work fine. The only thing is, that surge and sway ar interchanged, maybe I have only a fallacy^^. And the problem is even, that the sim makes an uncontrolled movement instead of standing still,when turning off
  12. yobuddy
    51,254Coins
    It's just a bit confusing as it looks like if you were to sit on it, it would just fall over?
  13. JohannesNicklas
    156Coins
    Construction is not the most stable, but adequate for the purposes.
    I am only responsible for the control, the construction of the real sim is someone else part.
  14. yobuddy
    51,254Coins
    @JohannesNicklas
    I gotcha buddy :thumbs
    If it were to be built full size it would be very dangerous. :D
    Noorbeast's post number 7 should help you a lot.
    take care buddy,
