2DOF simulator servo model
Discussion in 'DIY Motion Simulator Projects' started by Svensson, May 7, 2015.
  1. Svensson
    Svensson New Member
    Sweden
    284Coins
    Hi
    Just wanted to try building a simulator with servos before getting in to the real deal.
    Had a rc car just laying around that i could salvage servos and some other stuff from.
    2x Hitec HS-311 servo
    1x Traxxas u-joint
    1x Arduino nano
    Some cardboard
    I've followed this guide when setting up simtools http://www.xsimulator.net/installing-simtools/
    I've used eaorobie's arduino code and have set up my servos like he's done. http://www.xsimulator.net/community/threads/rc-model-for-motion-simulation.4600/
    Now to the problem. When testing the output to the servos, the servo that is connected to pin 5 to the arduino, only moves between 0-90 degrees. When it at 90 degrees it moves back to 0 again. The other servo connected to pin 4 only moves to 90 and stays there. See video for more detail
  2. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    i have managed to make rc servo move with @eaorobbie code this way
    connection diagram http://www.xsimulator.net/community/threads/rc-model-for-motion-simulation.4600/
    arduino code http://www.xsimulator.net/community/marketplace/rc-model-code-for-arduino-uno-2dof-expandable.89/
    interface setup - IMPORTANT - Assuming a 2DOF for SimTools 2 the Interface Output should be set like this R<Axis1a>~L<Axis2a>~ https://www.xsimulator.net/community/attachments/rcsettings-jpg.48565/
    and for expanding code to use more servo http://www.xsimulator.net/community/threads/my-project-guide-me.5682/#post-59262
    and here it is moving with game
    thnx to @eaorobbie i made my first project here and i am keep going
    • Like Like x 7
  3. christian
    christian Member
    Germany/München
    967Coins
    2DOF, SCN5, SimforceGT
    nice video
  4. Svensson
    Svensson New Member
    Sweden
    284Coins
    I see. I will tweak around with the settings to see if I solve the problem. Thanks
  5. John458
    John458 Member
    Retail
    Brisbane
    393Coins
    Hey Guys,
    Cant find a wiring diagram for 3dof using Arduino and monster moto, plenty of 2d0f... can someone help. I have found a few 2d0f and 1 3dof but that is not using arduinos and mottos (see attached) I can't find the links anymore...sorry
    I am creating a scale model myself using ardunio and monster moto boards before I go full scale. I want to make sure the model is working properly, i have created this board (just waiting on the pots)
    and making the 3 motors pitch roll and yaw.
    any help would be very much appreciated :)
    Cheers
    Dave
    154,570Coins
    +11,190 / 57 / -2
  7. aiman anuar
    aiman anuar New Member
    Malaysia
    118Coins
    2DOF, 6DOF
    hi, where can i refer to set the axis assignment for 2 DOF?
    currently i am using this setting.
  8. obobo
    obobo Active Member
    1,323Coins
    It's not pitch and roll that you should have ??
    154,570Coins
    +11,190 / 57 / -2
    Those settings look to be from the SketchUp powered model tutorial. You should be using a configuration that suits your design and hardware, even if that happens to be a 2DOF model in something like SketchUp.
    This is another member's project page, you need to start your own and post information about your project so members can give advice. Please start your own project thread here: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
  10. xiejin
    xiejin New Member
    CHAINA
    94Coins
    Why there is a delay
  11. smallmadtv
    smallmadtv The Astrophotgrapher Gold Contributor
    Tech Manager
    Belgium - Sambreville
    100Coins
    2DOF, 3DOF, Arduino, 4DOF, 6DOF
    Hi There, Hope you are well !
    Any idea how to optimize the code?
    I try to rework it, but still have some glich. The input seems to not be correctly manage and send thru other servo (I've extended to 3do, 4 dof but testing unde 2dof)
    The first symptoms where when I was on -1 that trow the servo way out of range...
    Then I see the servo totally out of mind... you change R and it move the number 2...
    I have reworked multiple time, but as I'm not an expert, it start to be quite difficult...
    - Added an LCD to get some message
    - try to add a Stop code '*' in Simultool. R<Axis1a>~L<Axis2a>~F<Axis3a>~V<Axis4a>~*
    - Try change the plug
    - Try to optimize the Scaling
    Noting really work...
    Code:
    // RC Model Servo
    // Original code By EAOROBBIE (Robert Lindsay)
    // Completely mangled by aarondc
    // Reworked by Andy Strappazzon
    // For free use for Sim Tool Motion Software
    // LibrairieLCD
    // Ecran LCD
    #include "LiquidCrystal.h"
    LiquidCrystal lcd(3,2,11,10,9,8);
    #include <Servo.h>
    //#define DEBUG 1                                    // comment out this line to remove debuggin Serial.print lines
    const int kActuatorCount = 2;                       // how many Actuators we are handling
    // the letters ("names") sent from Sim Tools to identify each actuator
    // NB: the order of the letters here determines the order of the remaining constants kPins and kActuatorScale
    // R<Axis1a>~L<Axis2a>~F<Axis3a>~V<Axis4a>~*
    const char kActuatorName[kActuatorCount] = { 'R','L' };   ////'L', 'F', 'V'
    const int kPins[kActuatorCount] = {4,7};                        // pins to which the Actuators are attached 4,5, 6, 7
    const int kActuatorScale[kActuatorCount][2] = { { 1, 179 },         // R Actuator scaling ,
                                                   { 1, 179 }          // L side Actuator scaling
                                                  //{ 1, 179 } ,         // F
                                                   //{ 1, 179 }           // V
    const char kEOL = '~';                                    // End of Line - the delimiter for our acutator values
    const char kESP = '*';                                    // end of Order - Execute positioning
    const int kMaxCharCount = 3;                              // some insurance...
    Servo actuatorSet[kActuatorCount];                        // our array of Actuators
    int actuatorPosition[kActuatorCount] = {90,90};     // current Actuator positions, initialised to 90 , 90, 90, 90
    int currentActuator;                                      // keep track of the current Actuator being read in from serial port
    int valueCharCount = 0;                                   // how many value characters have we read (must be less than kMaxCharCount!!
    int dataFromSimtools[kActuatorCount];                     // Data From Simtools live
    // set up some states for our state machine
    // psReadActuator = next character from serial port tells us the Actuator
    // psReadValue = next 3 characters from serial port tells us the value
    // psEndOfLine
    enum TPortState { psReadActuator, psReadValue, psEndOfLine };
    TPortState currentState = psReadActuator;
    void setup()
        // attach the Actuators to the pins
        for (int i = 0; i < kActuatorCount; i++)
            actuatorSet[i].attach(kPins[i]);
        // initialise actuator position
        //for (int i = 0; i < kActuatorCount; i++)
            updateActuator(1);
        lcd.begin(16,2);
        Serial.begin(9600); // opens serial port at a baud rate of 9600
    void loop()
    // this code only runs when we have serial data available. ie (Serial.available() > 0).
    void serialEvent() {
        // Initialisation of variables
        char tmpChar;         // Character * or ~  RLVF
        int tmpValue;         // Value
        int oneAtTime;    // avoid multiple instance
        // Main While on Serial.available
        while (Serial.available()) {
            // if we're waiting for a Actuator name, grab it here
            if (currentState == psReadActuator) {
                              tmpChar = Serial.read();
                              // look for our actuator in the array of actuator names we set up
                               for (int i = 0; i < kActuatorCount; i++) {
                                                    if (tmpChar == kActuatorName[i]) {
        currentActuator = i;                        // remember which actuator we found
        currentState = psReadValue;                 // start looking for the Actuator position
        actuatorPosition[currentActuator] = 0;      // initialise the new position
        valueCharCount = 0;                         // initialise number of value chars read in
        break;
            // if we're ready to read in the current Actuator's position data
            if (currentState == psReadValue) {
                while ((valueCharCount < kMaxCharCount) && Serial.available()) {
                    // Step One grab the Serial Message
                    tmpValue = Serial.read();   // read Serial input
                    // If differnet from the  end of line charachter  '~' or end of message '*'
                              if ((tmpValue != kEOL)||(tmpValue != kEOL)) {
                               tmpValue = int(tmpValue);
                              // Send to LCD for debug ----------
                               if (currentActuator == 0){
                               lcd.setCursor(0,0);
                               lcd.print('R');
                               lcd.print(tmpValue);
                               if (currentActuator == 1){
                               lcd.setCursor(4,0);
                               lcd.print('L');
                               if (currentActuator == 2){
                               lcd.setCursor(8,0);
                               lcd.print('F');
                               if (currentActuator == 3){
                               lcd.setCursor(12,0);
                               lcd.print('V');
                                  // Hysterisis Dead band kill
                                  //if ((tmpValue < 0) || (tmpValue > 230)) tmpValue = 0;
                                // if ((int(tmpValue) < 130) && (int(tmpValue) > 120)) {
                               //  tmpValue = 123;
                              dataFromSimtools[currentActuator] = tmpValue;
                              actuatorPosition[currentActuator] = tmpValue;
                              valueCharCount++;
                             else break;
                              // if we've read the value delimiter, update the Actuator and start looking for the next Actuator name
                              if (tmpValue == kEOL || valueCharCount == kMaxCharCount) {
                                    // Adjust the TempValue to avoid division per Zero
                                    // scale the new position so the value is between 0 and 179   0 255
                                    actuatorPosition[currentActuator] = map(actuatorPosition[currentActuator] -24, 1, 255, kActuatorScale[currentActuator][0], kActuatorScale[currentActuator][1]);
                                    dataFromSimtools[currentActuator] = actuatorPosition[currentActuator];
                              // if we'read the end of Order execute the update of the servo
                              if (tmpValue == kESP || valueCharCount == kMaxCharCount) {
                                updateActuator(currentActuator);
    // write the current Actuator position to the passed in Actuator
    void updateActuator(int thisActuator) {
                    // Sent to LCD to debug
                     if (thisActuator == 0){
                     lcd.setCursor(0,1);
                     lcd.print('R');
                     lcd.print(actuatorPosition[thisActuator]);
                    if (thisActuator == 1){
                    lcd.setCursor(4,1);
                    lcd.print('L');
                    if (thisActuator == 2){
                    lcd.setCursor(8,1);
                    lcd.print('F');
                        if (thisActuator == 3){
                    lcd.setCursor(12,1);
                    lcd.print('V');
        //actuatorSet[thisActuator].write(actuatorPosition[thisActuator]);
            actuatorSet[i].write(actuatorPosition[i]);
    154,570Coins
    +11,190 / 57 / -2
    Can you please post pictures of your SimTools settings, as looking at the model movement they do not seem to be refined.
  13. smallmadtv
    Tech Manager
    100Coins
    I try with these:
    and these one where I double the info seems to work better:
    R<Axis1a>~R<Axis1a>~L<Axis2a>~L<Axis2a>~F<Axis3a>~F<Axis3a>~V<Axis4a>~V<Axis4a>~*
    I also try different Output type, Parity, or the 50ms... even the BitsPerSec...
    My current code is here:
    Code:
    // RC Model Servo
    // LibrairieLCD
    // Ecran LCD
    #include <Servo.h>
    const int kActuatorCount = 6;                       // how many Actuators we are handling
    const char kActuatorName[kActuatorCount] = { 'R', 'L', 'F', 'V', 'M', 'N' };   ////'L', 'F', 'V','M','N'
    const int kPins[kActuatorCount] = {4,5,6,7,12,13};                        // pins to which the Actuators are attached 4,5, 6, 7
                                                    { 1, 179 },         // L side Actuator scaling
                                                    { 1, 179 },         // F
                                                    { 1, 179 },         // V
                                                    { 1, 179 },         // M
                                                    { 1, 179 }          // N
    int actuatorPosition[kActuatorCount] = {90,90,90,90,90,90};     // current Actuator positions, initialised to 90 , 90, 90, 90
    // psEndOfLine
    // Setup of the system
    void setup()
            updateActuator(1);
        lcd.begin(16,2);    // Initialize the LCD Screen
    // Main loop not used
    void loop()
        break;
                              valueCharCount++;
                             else break;
                              // if we've read the value delimiter, update the Actuator and start looking for the next Actuator name|| valueCharCount == kMaxCharCount
                              if (tmpValue == kEOL ) {
                    lcd.setCursor(0,1);
                    lcd.print('R');
                    lcd.print(actuatorPosition[0]);
                    lcd.setCursor(0,0);
                    lcd.print('R');
                    lcd.print(dataFromSimtools[0]);
                    lcd.setCursor(4,1);
                    lcd.print('L');
                    lcd.print(actuatorPosition[1]);
                    lcd.setCursor(4,0);
                    lcd.print('L');
                    lcd.print(dataFromSimtools[1]);
                    lcd.setCursor(8,1);
                    lcd.print('F');
                    lcd.print(actuatorPosition[2]);
                    lcd.setCursor(8,0);
                    lcd.print('F');
                    lcd.print(dataFromSimtools[2]);
                    lcd.print('V');
                    lcd.print(actuatorPosition[3]);
                    lcd.print('V');
                    lcd.print(dataFromSimtools[3]);
  14. smallmadtv
    Tech Manager
    100Coins
    And in this kind of status it goes out of mind totally...
    Moving another axis... really strange..
    154,570Coins
    +11,190 / 57 / -2
    I can't see from your video that there are more than 3 axis, if there are more than 3 axis please post model pictures so they are clear.
    For a 3DOF the Interface Settings should be like this, so edit the code accordingly as well: R<Axis1a>~L<Axis2a>~F<Axis3a>~
    Leave out the Startup and Shutdown for now.
    What are your Axis Assignment and Tuning Center settings, please post pictures.
  16. smallmadtv
    Tech Manager
    100Coins
    I have these settings fortesting now :
    and forLFS:
    Does it really matter ? As I'm testing within Simtool, with axes screen:
    Seems, I'm two finger to have it correctly setup.... But can find the solution
    for me the problem remain in the arduino to read the serial messages without skip, jump or incomplete message
  17. Sam Neall
    Sam Neall Member
    84Coins
    Have you tried setting your baud rate differently?
    That’s what helped me with interruption issues.
  18. noorbeast
    154,570Coins
    +11,190 / 57 / -2
    The Axis Assignment total (horizontal total) should be around 100, not 100 per axis: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    A dedicated axis can be 100 percent allocation.
    If properly configured you should not need axis limiting, generally that is applicable to protect hardware like SCN actuators.
    Grab a copy of the SimTools manual and keep it handy for reference: https://www.xsimulator.net/community/faq/rtfm-start-with-the-official-simtools-documentation.117/
    Then see the motion profile refinement tips and do each axis initially one at a time: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  19. smallmadtv
    Tech Manager
    100Coins
    hi!
    Thank you forthe reply.
    Yes, try multiple one without success. The only parameter that seems to have an impact is this one in red:
    When I put 50 the error seems to reduce. Note that if I put less than 30, the model jiggle around
    :D :D :D :D
    154,570Coins
    +11,190 / 57 / -2
    As per my earlier comment re what appears to be 3 axis: https://www.xsimulator.net/community/threads/2dof-simulator-servo-model.6851/#post-210879
    Can you please explain your Interface Output settings, as they look to be messed up to me for a 3DOF:
