No data from the game.
Discussion in 'SimTools DIY Version' started by Alex36, Nov 30, 2016.
  1. Alex36
    Alex36 New Member
    rus
    279Coins
    Hello!
    I have a problem.
    I have installed the game and WarThunder plugin.
    Game manager games sees, but there is no data in the Tuning Center.
    What am I doing wrong?
  2. obobo
    obobo Active Member
    1,323Coins
    post in english please
  3. Thunderbird34
    Thunderbird34 New Member
    15Coins
    I have the same problem as my previous speaker, I get no data from the game transferred to the Gamingcentrum? Arduino with SMC 3 with the recommended setup for the interface Simtools Setup Setup for Simtools is very straight forward: [A <Axis1>] [B <Axis2>] [C <Axis3>] Set for 10bit binary output Baud rate 500000, N, 8, 1 (10ms delay) As soon as I switch the tunning, data max / min, then reset and drive with the car there is no change of numbers, and on the Arduino no LED TX / RX! But can the axes in the Simtool start? Come first no further, who knows advice
    152,541Coins
    +11,085 / 56 / -2
    Please post pictures of all settings.
  5. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    What is the date on the plugin that you are using?
  6. Thunderbird34
    15Coins
    My interface and Arduino settings
  7. Thunderbird34
    15Coins
    Must what be clicked, perhaps, in the Asseto Corsa to be able to send data to Arduino? I cannot simzply understand where the problem could be.Mit Raceroom I also have no function.
    About Game - managers, I can start the impulses, limit etc.
    If the port COM must be shifted(adjusted) under settings(discontinuances).
    Greeting
    Dimitri
  8. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    if one game moves its not your in simnulator setup meaning the arduino is fine.
    152,541Coins
    +11,085 / 56 / -2
    It is hard to assist without more detailed information.
    What are your Axis Assignment settings?
    Are the games being patched for motion and if so to what directory path?
    Does Game Manager turn blue and say Connected when the game is running?
  10. Alex36
    Alex36 New Member
    rus
    279Coins
  11. xiejin
    xiejin New Member
    CHAINA
    94Coins
    I met the same problem as you.
  12. Alex36
    Alex36 New Member
    rus
    279Coins
    Prompt, who works works WarThunder plugin without any problems?
