Idea for A motion simulator
Discussion in 'DIY Motion Simulator Projects' started by Kingsfire, Nov 30, 2016.
  1. Kingsfire
    Kingsfire New Member
    Texas
    428Coins
    3DOF, DC motor
    I have constructed a 3d model of an Idea I have for a motion sim. I will attach drawings I have made so far. Also had a question. Has anyone tried using slewing drives in a motion simulator? Please take a look at the plans I have drawn up and let me know what you think.
    153,758Coins
  3. Wanegain
    Wanegain Active Member
    Bruxelles
    2,018Coins
    It can work, but I'm not sure you want yaw effect on a seat mover...
  4. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    Same basics as Rock N Ride simulator(first motion game simulator ever sold)but R N R needs les power.
    There was one with a third axis (yaw)to ,the only thing they did was a bearing between floorplate and stand.
  5. Kingsfire
    Texas
    428Coins
    3DOF, DC motor
  6. RacingMat
    21,082Coins
    would you be kind to share your design with some pictures inserted in your post?
    a simple drag and drop and it's done :)
  7. Kingsfire
    Texas
    428Coins
    3DOF, DC motor
    I don't have anything built yet. I have a 3d model which I could post screen shots of or maybe a jpg if I can generate one from the model. Let me know if this would be good. As soon as I start construction I will post some pics.
  8. obobo
    obobo Active Member
    1,323Coins
    this is good
    But few people want to spend a lot of coinsto get your project pdf
  9. Kingsfire
    Texas
    428Coins
    3DOF, DC motor
    I did not realize this. Thanks for letting me know. I will try to embed some jpg of my models.
  10. Kingsfire
    Texas
    428Coins
    3DOF, DC motor
  11. obobo
    obobo Active Member
    1,323Coins
    An interesting concept
    But I do not quite see how the seat is articulated
  12. Kingsfire
    Texas
    428Coins
    3DOF, DC motor
    a slewing drive is used on esch axis. Slewing drives consist of a "lazy susan" type bearing driven by a motorized worm gear. they are used in such things as robot arm articulation and steering mechanisms for multi-wheeled vehicles. here is a picture: slewing drive.jpg
  13. obobo
    obobo Active Member
    1,323Coins
    impressive, but not the cheapest way no ?
  14. obobo
    obobo Active Member
    1,323Coins
    you put an electric motor instead the hydraulic in picture ...
