  1. gpau
    gpau Member
    550Coins
  2. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    That's probably the cause of power being drawn on idle as ball screws are easily back-driven, so the actuators are continuously battling the weight above them. It would seem likely that the addition of gas struts would help in that regard. In terms of holding power a lead screw would be better but then the trade off is higher friction.
    Hope to start building my own actuators as this rig of yours looks like a heap of fun!
  3. SilentChill
    20,604Coins
    No they don't move, I can sit on the rig with no power and the rig is solid it doesn't move.
    The problem is the power is constantly there because of the reason I explained above ;)
  4. SeatTime
    The cruise was great as always - actually on leave until early January, so hopefully can finish off allot of projects that I have on the books. I use 3 x 1100mm/100N gas struts which only lift 10kg each, but I think they are a good compromise for balancing the rig without dampening the movement too much. Talking about motors - don't know if this is relevant but, I did tests on one of Motion Dynamics industrial spec motors early on when I was building my actuators (see picture below from my thread), which were quite a bit larger (size wise) than the motors I ended up going with, but found in testing that they would not track properly - from what I could tell it seemed to be how the motor was wound and there seemed to be a bigger gap between the magnetic poles when it turned (it could not turn in small increments like my other motors - so would stop either just past or before the target). Don't know if that may be relevant to your motors or not - but figured worth mentioning?
  5. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    Hi Silentchill
    You have 1.9mtr hight, did you spred your actuators to lower youre sim.
    There is much more force needed to create heave from the lowest point when actuaters are allmost horizontal,than if they stand on a 45 degrade angle.
    I am only looking mechanical.
    Sorry for the bad english.
  6. SeatTime
    Hi @SilentChill - just noticed from @wannabeaflyer2 comment that you used rose joints on the lower frame - are they also on the upper frame - if so, do you have issues with the actuators twisting? From your video the actuator on the right is twisting quite a bit - not good for tracking.
  7. SilentChill
    20,604Coins
    These motors have 4 brushes rather than the usual 2 I dont know if that would affect it or not? Perhaps taking 2 opposite brushes out may smooth it out ? I dunno lol
    Yes it is twisting, I need to weld my UV joints on to the bottom.
  8. SilentChill
    20,604Coins
    Yes I did when in the centre position the actuators are at 45 degrees, this is a limitation I cannot get past unfortunately.
  9. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
  10. SeatTime
    -Mmm don't think it would be a good idea to remove the brushes - Yea I thought you had purchased UV joints. Funny thing I have noticed some so called professional sims coming out of many countries which have used rose joints on both top and bottom of their actuators o_O- they twist so much that you can sometimes hear them smashing into the joints stops - says so much for the quality of the engineers behind them.
    One of my favorites - @noorbeast will remember him - I did mention it too him before we worked out he was not a DIYer , he did not understand what I was talking about...
    - his later 'professional' sim still uses this setup :rolleyes:
    I know, I know only an engineer could find this funny...
  11. SilentChill
    20,604Coins
    Oh well after a good few stages on Dirt another of my couplers sheared in half. I have ordered new ones to replace all of the cheapo ones that I bought.
    Always something else grrrrr it was running sweet too
  12. Alexey
    Adelaide, Australia
    8,066Coins
    Ah. I read that like, with your finger, you are able to move the rig up and down.
  13. wannabeaflyer2
    london uk
    8,356Coins
    Hi mate what type of couplers u using flexi or cush drive ?
  14. BlazinH
    16,698Coins
    Definitely keep all four brushes. :eek: Four is always better than two anyway and two would be less smooth, not more. Besides, when a motor is designed for four brushes you can't take any out. This would leave power being applied to only 180 degrees on the armature or in other words just half of it. On two brush motors the opposite brush is the opposite polarity but on four brush motors the opposite brush is the same polarity. So taking two out would leave two brushes at 90 degree angles to each other, not 180 degrees like in two brush motors.
  15. SilentChill
    20,604Coins
    Sh!t ones !!!!!! hahaha :D I had these installed
    I have now sheared 2 of these lol I always go cheap first and no I will never learn ;)
    I have replaced the first one with one of these and I have order 8 more just in case :)
    • Useful Useful x 2
  16. SilentChill
    20,604Coins
    Yeah I decided against it, my stupid mind works in stupid ways :D
  17. SilentChill
    20,604Coins
    Haha sorry I should of been more specific, I can turn the ballscrew with my finger and thumb ;)
  18. wannabeaflyer2
    london uk
    8,356Coins
    hi @SilentChill yep the 2nd one would be the better option , the 1st will quite literaly unwind itself which is what you found .. just made for lighter loads ..
  19. BlazinH
    16,698Coins
    And if the brand name of those couplers is any indication you will be very satisfied with them. :D
  20. My.stAr
    My.stAr Active Member
    Engineer
    1,065Coins
    DC motor
    Hi @SilentChill
    you have a fantastic project:thumbs lots of ups and downs, but it's great to see that you have more ups;)
    i could learn a lot, so thanks for being so detailed.
    atm i have one question. did you use sound transducers in your first version? did you install them also in your recent build? I know, that they shake with another frequency, than the actuators ever could, but do they add another step in realism?
