My Sim Cockpit [2dof 24v]
Discussion in 'DIY Motion Simulator Projects' started by dedraro, Dec 3, 2016.
  1. My.stAr
    My.stAr Active Member
    Engineer
    1,064Coins
    DC motor
    Thanks. that's a little more than i expected:o:
  2. dedraro
    dedraro Active Member
    105Coins
    Guys I have a question for you, for you it is best to connect the motors to the potentiometers using gear / belt system or a joint like this?
  3. Blame73
    Blame73 Well-Known Member
    8,305Coins
    A lot of us connect pots (hall effect highly suggested) with that joint
    152,553Coins
    +11,086 / 56 / -2
    The correct size flexible coupling is the way to go.
    This type of flexible coupling are the strongest:
  5. dedraro
    105Coins
  6. Blame73
    8,305Coins
  7. dedraro
    105Coins
    Ok perfect, now I just have to wait for all the components :D
  8. Nick Moxley
    Tho this style does come at a cost, and for what reason you would need any type of real strength in this part is beyond me. The Pots internal resistance will be the only force it technically sees. o_O
    Edit, turns out Craig has "untwisted" a few of the cheap ones, but still Highly unlikely on a Seat mover.
  9. BlazinH
    16,671Coins
    But this type is not flexible to side forces like is needed for pots. This is good for motor to ball screw couplings for example but the the other type is better for pots.
    • Agree Agree x 3
  10. dedraro
    105Coins
    In fact 22 Euros for the joints is a bit too much, I think I will aim on those entirely of metal, which cost about half.
  11. Blame73
    8,305Coins
    Exactly, my pots are some 1/2 degrees misaligned and a flexible coupler was mandatory. But even if it would have ben perfectly aligned there are forces from the motors that make the structure torx, expecially in fast changes of direction (gear changes, bumps, ...)
  12. Blame73
    8,305Coins
    No need to spend that much. I bought something like these for 2,5€ each...
  13. Nick Moxley
  14. dedraro
    105Coins
    152,553Coins
    +11,086 / 56 / -2
    Done, find it here: https://www.xsimulator.net/community/faq/how-to-connect-protect-a-potentiometer.13/
  16. dedraro
    105Coins
  17. dedraro
    105Coins
    It's almost everything, just look the aluminum from motedis.de, and psu and fans. :D
    I only have one doubt, the potentiometers (Sakae 10K fcp22e) are very hard to turn, it is normal for you?
  18. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    you made the cardstock :)
    I can give you some tips on connecting potentiometers, for safety and, if you have the opportunity to use a lathe, put the potentiometers on the opposite side of the lever, this will save you in the event that the lever has a lap full, simply pierce the 'crankshaft and use a screw collar where to insert the flexible coupling
    hai fatto la scorta di schede
    posso darti un consiglio sul collegamento dei potenziometri, per sicurezza e se hai la possibilita di utilizzare un tornio, metti i potenziometri dalla parte opposta della leva, questo ti salverà nel caso in cui la leva facesse un giro completo, ti basta bucare l' albero motore e usare una vite a colletto ove inserire il giunto flessibile
  19. dedraro
    105Coins
    You're right, I had not thought of this, I will assess whether to pierce the shell of gear motors, I would not make irreversible changes.
    I bought many cards in anticipation of my future project or a 4dof, 3DOF consists of 4 engines with lifting effect more traction loss.
    Hai ragione non avevo pensato a questo, valuterò se forare la scocca dell'ingranaggio dei motori, non vorrei effettuare modifiche irreversibili.
    Ho comprato molte schede in previsione del mio progetto futuro ovvero un 4dof, 3dof composto da 4 motori con effetto sollevamento più il traction loss.
  20. spyderwash
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    It is advice but do it, you could solve many problems and damage in the future, especially once you start, it's not hard work enough to be precise as to pierce the 'tree.
    so you're ready for a future upgrade and I think that makes more sense, though ritego, although amande seat cover movement, which heave must be on the whole structure and not only the seat but at the level of sensations prefer to put the loss of traction
    è un consiglio ma fallo, in futuro ti potrebbe risolvere molti problemi e danni , specialmente appena si inizia, non è difficile come lavoro basta essere precisi a bucare l' albero.
    quindi sei già pronto per un futuro upgrade e credo che sia quello più sensato, anche se ritego, pur essendo amande del movimento solo sedile, che heave debba essere su tutta la struttura e non solo sedile ma a livello di sensazioni preferisco mettere la perdita di trazione
