NIGHTMARE PLZ HELP
Discussion in 'Assetto Corsa' started by Vdub180, Dec 17, 2016.
  1. Vdub180
    Vdub180 Member
    England
    148Coins
    hi all been using my rig now for over 12 months without major problems but recently I altered some files in my config video file for my rift and messed it all up, since then I have lost all my motion on my rig so here what I have done so far without any luck
    reinstalled acs
    deleted files and repatched
    reinstalled simtools
    reinstalled acs on drive c
    don't know what else I can do its always worked perfectly
    windows and simtools are installed on drive C and steam and games on drive F
    all games work perfectly apart from acs
    152,433Coins
    +11,077 / 56 / -2
    I really don't understand why you would be fiddling with the config file, nor why that would affect your motion settings. Is it the CV1 that you have?
    What path are you patching to?
    Does Game Manager turn blue and say Connected?
  3. Vdub180
    Vdub180 Member
    England
    148Coins
    Turns green says connected but not blue
    Tuning centre dont move at all copy patch to steam common assetto corsa trying to get pics
  4. Vdub180
    Vdub180 Member
    England
    148Coins
  5. Vdub180
    Vdub180 Member
    England
    148Coins
    This
  6. ferslash
    ferslash Active Member
    4,798Coins
    what about re-install everything.... re-install windows is not that hard :D (save your drivers before you delete everything)
    152,433Coins
    +11,077 / 56 / -2
    You can just close the security warning.
    Try un-patching Assetto Corsa, close SimTools, restart SimTools as Admin and re-patch.
    What are your Interface Settings and Axis Assignments?
    And can you please show a readable shot of the Tuning Center values.
  8. Blame73
    Blame73 Well-Known Member
    8,305Coins
    Try renaming the Assetto Corsa folder under your documents folder then do an integrity cache check under Steam so that it'll download it again.
  9. Vdub180
    Vdub180 Member
    England
    148Coins
    I'll try that out but I have reinstalled the game 3 times was gonna try and reinstall steam as well
  10. Blame73
    8,305Coins
    I don't know if reinstalling the game AC rebuilds the doc folder. Try renaming it, it's way faster.
    Try also deleting the AC user\appdata simtools folder
    EDIT:
    C:\Users\[YOUR_NAME]\AppData\Local\SimTools
    delete the AC related settings
  11. Vdub180
    Vdub180 Member
    England
    148Coins
    ok guys all working i did integrity cache and turned off force 32 bit in options and now it works lol thanks again
