Showroom 6DOF racing platform 12v dc 3.6kw arduino and mm/SMC3
Discussion in 'DIY Motion Simulator Projects' started by bruce stephen, May 3, 2016.
  1. bruce stephen
    general contractor
    michigan
    9,115Coins
    20161223_091853.jpg 20161223_093115.jpg 20161223_093317.jpg 20161223_094051.jpg 20161223_125153.jpg 20161223_125311.jpg 20161223_125509.jpg
    Rebuilt my gt wheel. Got rid of lower buttons added a button on each side up top. Added bluetooth 4.0 with bluehid board and battery in center of rim.
  2. Nick Moxley
    I look forward to hearing how you get on with the Bluetooth, What board exactly is that ?
  3. bruce stephen
    general contractor
    michigan
    9,115Coins
    • Informative Informative x 4
  4. Justin Dail
    Justin Dail Member
    Georgetown South Carolina
    393Coins
    3DOF, SCN5
    Hey Bruce nice rig and osw wheel is a great addition I'm running one of the older argon units
    But anyways I have a question do you have a link were too find the wire connections too solder to monster moto board for - +
    Would be a big help I'm currently solder wire straight too board takes a lot of time
  5. bruce stephen
    general contractor
    michigan
    9,115Coins
    20170107_144225.jpg @Justin Dail i just solder 14awg stranded to the supply side then I solder a flange spade wire connector to the output.
    @Nick Moxley three weeks on the Bluetooth it's awesome I haven't had to charge yet, no missed shifts. Worth the price to eliminate cords.
    I also updated the title to more accurately reflect the state of my project. I do still plan on the surge plate upgrade but it won't happen until much warmer weather. I have found an old Pilates machine with a nice set of nylon rollers and a couple tracks I will use.
  6. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    Curious to know if the pillow blocks have prevented more hall sensor failures?
  7. bruce stephen
    general contractor
    michigan
    9,115Coins
    Yup I haven't replaced one since implementing.
  8. bruce stephen
    general contractor
    michigan
    9,115Coins
    I got the idea from another 6dof here that was using similar motors as me but they put the assembly on the top of the motor.
  9. bruce stephen
    general contractor
    michigan
    9,115Coins
    new dash made with simhub for the rgb leds and dash meter pro for the android 7" tablet. there are 47 leds total. the 16 led ring is a fuel gauge.
    • Like Like x 6
    • Winner Winner x 3
  10. RandomCoder
    Control Engineer
    1,674Coins
    That is one gorgeous looking dash! Nice work.
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    Its been awhile since Ive updated this thread. Its time to upgrade to @SeatTime style actuators.
    I started by just copying the specs from @wannabeaflyer2 his pdf is very detailed. But as my motors and other parts were different I started just drawing my own. I have finished the main structure including plates,spacers, bearing retainer. I will start adding the position sensor assembly and limit switch brackets next.
  12. bruce stephen
    general contractor
    michigan
    9,115Coins
    • Like Like x 9
  13. llluis
    Quebec
    1,632Coins
    What are you print settings (material and infill)?
  14. bruce stephen
    general contractor
    michigan
    9,115Coins
    I am using pla. At 100percent infill. I started with petg g but i think pla will be plenty strong. I have a bunch of pla sitting here so thats what im using. If it doesnt hold up its back to pet or abs.
  15. wannabeaflyer2
    london uk
    8,351Coins
    Thing of Beauty @bruce stephen glad the drgs were of some help . can I ask what the yellow printed part does or holds ?? me being nosey LOL ..aha got it liner bush of some sort :)
  16. bruce stephen
    general contractor
    michigan
    9,115Coins
    it is holding the Igus bearing in place. I chose a bearing that had a flange. I'm trying to reduce amount of parts bought example: with the spacers (they capture the nuts at the bottom) it reduces the nuts and washers from 24 each down to 16 each. If you see early pitfalls please let me know as this is all "suck it and see". :D
  17. bruce stephen
    general contractor
    michigan
    9,115Coins
    Slow progress
  18. Nick Moxley
    Impressive. Keep it up Bruce.
  19. OZHEAT
    OZHEAT Active Member
    Australia
    2,459Coins
    3DOF, DC motor
    @bruce stephen
    Are you going to put a lower bearing on the ballscrew?
    Motor's bearings do not like thrust loads on them and the wave washer used behind the motor bearing for thrust forces will quickly be useless.
    Also if you use an "oldham" type of coupling watch out for hitting lower hard limit as it will probably lift the ballscrew up and you may lose the balls from the screw assembly.
  20. bruce stephen
    general contractor
    michigan
    9,115Coins
    bk12 bearing but it hasnt arrived yet.
