problem with cv1 with flyinside
Discussion in 'VR Headsets and Sim Gaming - Virtual Reality' started by lysa elec, Dec 23, 2016.
  1. lysa elec
    lysa elec LYSA ELEC
    - 26Coins
    I have a problem when I want to start P3d 3.4 with my CV1 (window 7)
    Only pd3 start correctly not with cv1
    I have the following message:
    flyinside requises desktop composition (aero in order to run
    aero requises an aero compatible theme
    what happen ?
    152,541Coins
    +11,085 / 56 / -2
  3. lysa elec
    lysa elec LYSA ELEC
    - 26Coins
    ok i try that
  4. lysa elec
    lysa elec LYSA ELEC
    - 26Coins
    i try the solution but nothing
    aéro is enable in settings
    152,541Coins
    +11,085 / 56 / -2
    I would suggest posting the issue to the FlyInside forum. There have been lots of complex issues of late with many variables, such as P3D3.4 + hotfix, Oculus rolling out ASW and Nvidia driver problems.
  6. lysa elec
    lysa elec LYSA ELEC
    - 26Coins
    The function(office) ASW works you it on Windows 7 ?
    thanks
    152,541Coins
    +11,085 / 56 / -2
    ASW messes up the performance of FlyInside but that should not be causing the error you are getting.
    Oculus supports:
    NVIDIA GTX 970 / AMD 290 equivalent or greater
    Intel i5-4590 equivalent or greater
    8GB+ RAM
    Compatible HDMI 1.3 video output
    3 x USB 3.0 ports
    Windows 7 SP1 or newer.
  8. lysa elec
    lysa elec LYSA ELEC
    - 26Coins
    see one pisture of my probleme
  9. lysa elec
    lysa elec LYSA ELEC
    - 26Coins
    152,541Coins
    +11,085 / 56 / -2
