WIP - 2DOF GT seat mover + Traction loss (wiper motor/arduino/MM)
Discussion in 'DIY Motion Simulator Projects' started by lilted86, Dec 30, 2016.
  1. lilted86
    lilted86 Member
    Malaysia
    489Coins
    Hello everyone,
    so this coming new year im planning to do my self a 2DOF seat mover...most preferably using f1 seated position style. So i have spend almost half year reading and gaining knowledge how to build this thing. So yeah, please help me during my adventure yes?
    this project is inspired by racingmat's Finished 2DOF 12V DC wiper arduino playseat
    Link to his project : viewtopic.php?f=36&t=1617
    he has very detail instruction so thanks racingmat!..without your guidance , i dont know what happen next.
    and also to very big thanks to x-sim team for the AWESOME SOFTWARE!!! and its community that very helpful!!..i feel so awesome now!
    i have ordered monster motor board 2pcs (1 for backup or for each individual motor)
    Link to the shop : http://www.dx.com/p/monster-moto-shield ... GPOeBt95pg
    next i will go find some useful wiper motors at scrap yard (or maybe a new ones).
    SO what type of automotive wiper motor that should i looking for??...i read somewhere that finding the truck or minivan with bigger wiper blade should have a strong wiper motors?...it is true?..well im going for cheap solution first...i know there's somewhere selling better motor like motion control motor from aussie i guess?..well its kinda expensive for my budget...maybe next time
    Minor Update : 30/12/2016
    instead going for F1 seat position..i choose GT seating posing..less headache.. [​IMG] ..
    i will be using the measurement from motiondave (thanks to him!!..i read somewhere in this forum about those measurement) and might be adjusting a little bit
    So this a basic measurement that im going to use
    Photo credit to motiondave
    this is his final build using the measurement (i supposed)
    photo credit to motiondave
    instead of using screws and bracket..i decided to weld all the joint together..i already sent the design to welder shop..so wanting them to quote me price..
    and owh yes!...my arduino UNO board is arrived!!!
    i got it here : http://www.dx.com/p/uno-r3-atmega16u2-d ... GXvUht97cs
    its a clone arduino Uno..what the heck..look same to me..so im going to use it
    Same day update!
    i have decided to add a traction loss and using GT seat style to my project
  2. lilted86
    lilted86 Member
    Malaysia
    489Coins
    151,467Coins
    +11,038 / 56 / -2
  4. lilted86
    lilted86 Member
    Malaysia
    489Coins
    hmmm...interesting...so i have decided to add the traction loss using wiper motor..going to redesign my draft now..
    instead of using lazy susan..any other choice?
  5. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    My system works awesome! No issues what so ever with the load distribution nor the traction loss.
    Good luck with your build!
    If I can help ask away
    • Friendly Friendly x 3
  6. lilted86
    lilted86 Member
    Malaysia
    489Coins
    awesome..thanks mate!...btw your rig is superb..inspired me too
  7. Brett Horton
    Tampa FL
    118Coins
    Great to hear!
    I learned a lot from this website, Nick Moxley and Norbeast!
    Tons of help available here
    • Friendly Friendly x 2
  8. lilted86
    lilted86 Member
    Malaysia
    489Coins
    awesome..yeah seen their post everywhere..seem they are pretty well known here
  9. lilted86
    lilted86 Member
    Malaysia
    489Coins
    2/1/2017
    Happy new year X-simulator!!!
    so today i have complete a design for my project..using google sketch up..take whole day to finish it!
    Please let me know your opinion and idea..
    this is my detailed measurement for traction loss and seat mover
    Final product (if nothing to change)
    back.jpg Front.jpg Overall back.jpg Overall front.jpg overall.jpg Side.jpg Top.jpg
    Im not sure if i want to proceed using square tubing or going for profile aluminium 2020. I dont have exact measurement for front bearing (lazy susan or custom bearing with shaft) and U-joint..
  10. Brett Horton
    Tampa FL
    118Coins
    I would decrease the angle of the traction loss motor to the linkage attachment point. Lower the motor a bit. you will lose some potential movement due to linkage geometry.
  11. lilted86
    lilted86 Member
    Malaysia
    489Coins
    shall i move the traction motor beneathe the seat mover?..plus my estimation is only 25mm for traction loss front bearing length
  12. Brett Horton
    Tampa FL
    118Coins
    Whatever needed to reduce the angle. You always want to setup your initial rods / linkages at 90 degrees if you are trying to accomplish equal movement both directions (we are)
    You could rotate the traction loss motor 90 degrees down and accomplish this quite easily.
  13. lilted86
    lilted86 Member
    Malaysia
    489Coins
    okey then..thanks!..i will look into during fabrication..thanks again for the tips!
  14. lilted86
    lilted86 Member
    Malaysia
    489Coins
    5/1/2017
    just a minor update..i have decided to choose aluminium profile extrusion 2020 as the material for this project..yes 2020 is a little bit small.. but im very positive that this tubing is more reliable the steel tubing with welding.
    and for the front traction loss bearing...i have found my used bearing clutch from my old car...its height is around 3cm and 7cm wide...able to withstand so much force as its main function is to push and disengage clutch plate from flywheel..
    so next is to do some cutting and remeasurement..
  15. Nick Moxley
    17,056Coins
    Distance from TL pivot isn't exactly ideal. Tho i can tell your going for as small of foot print as possible....some thing's like this will have to be forgiven...Bearing looks a tad overkill, but if you got it for Free, Who cares....just make it work.
  16. lilted86
    lilted86 Member
    Malaysia
    489Coins
    yup i get it for free...and what do you mean by distance from TL..sorry that my english is not my native language..
  17. Nick Moxley
    17,056Coins
    Think to yourself.....where does a Real car pivot from in a Traction loss moment ? Hopefully that should help explain what im saying.
  18. lilted86
    lilted86 Member
    Malaysia
    489Coins
    aah..okey..i understand..will make some adjustment later..but i get what you mean @Nick Moxley ..thanks
  19. lilted86
    lilted86 Member
    Malaysia
    489Coins
    13/1/2017
    So today my monster moto controller has arrive..i ordered 2 unit but i only receive 1 piece..going to check with the supplier...
    Meanwhile i will procedd with the seat mover until i receive another unit for traction control.
    Cant wait to complete it!!!
  20. Lorien31
    Lorien31 Member Gold Contributor
    IT System Specialist
    140Coins
    You should test those Monster Motos right away, because a lot of the clones are faulty. Not that you have to wait for replacements or not get a refund.
