Slow Forum Navigation
Discussion in 'Forum and Website' started by Blame73, Jan 4, 2017.
  1. Blame73
    Blame73 Well-Known Member
    8,315Coins
    Lately - 2/3 weeks - the navigation on xsimulator is really slow on my side. It takes forever to start loading pages, then it speeds up. I'm on a 50/20 fibre line.
    Sometimes it also gives me dns errors.
    Is it happening to you too?
  2. RaceRay
    Hamburg, Germany
    23,892Coins
    You are located in italy, right? Do you experience same slow times on other websites from germany as well or only here?
  3. Blame73
    8,315Coins
    It took me 10 seconds right now to open this page. Let me check and report back.
    Yes, Italy
  4. Blame73
    8,315Coins
    I opened 10+ german websites on the fly, no problem at all. Just here
  5. RaceRay
    Hamburg, Germany
    23,892Coins
    I changed some things. Is the problem still existent?
    Do you have any ad blocker running? What happens if you deactivate them?
    Please do another test:
    Enter this in CMD:
    ping xsimulator.net
    and
    tracert xsimulator.net
    It must be looking like this: http://take.ms/3POcq
    Let me know the results
    154,400Coins
    +11,181 / 57 / -2
    As you know I am on a terrible net connection @RaceRay and historically tend to notice issues, but I just ran WinMTK (combined ping and tracert) and there are no problems that I can see from my end in Australia.
  7. Rastus
    Rastus Active Member
    Sydney Australia
    11,518Coins
    @RaceRay Very slow here down under as well last 24 hrs. Am on on cable checked 29.6 mbps down and 1.92 mbps up which is usual check.jpg
  8. Rastus
    Sydney Australia
    11,518Coins
  9. Rastus
    Sydney Australia
    11,518Coins
  10. Rastus
    Sydney Australia
    11,518Coins
    @RaceRay Don't know if that helps I wouldn't have a clue what it all means just followed your instructions. all Greek to me!!
  11. RaceRay
    Hamburg, Germany
    23,892Coins
    @Rastus your tcp packages are going around the complete world:
    Going first to US west coast (palo alto) ->
    than over the north american continent ->
    over the atlantic sea ->
    to xsimulator server located germany
    As you can see in your trace route it even takes more than 300 ms to reach the US west coast. If you add all the further routes it's obvious why the loading time is very slow for australian visitors. At the moment i can not speed up the connection for our australian friends without moving the server to a location at US west coast:(
    The thread starter is coming from italy so the issue is probably be caused by something different, not by the amount of hops and the travel distance.
  12. Blame73
    8,315Coins
    Hmmm, doesn't seem to be bad, but the navagation is still slow
    Code:
    Microsoft Windows [Versione 10.0.14393]
    (c) 2016 Microsoft Corporation. Tutti i diritti sono riservati.
    C:\Users\Davide>ping xsimulator.net
    Esecuzione di Ping xsimulator.net [178.63.100.131] con 32 byte di dati:
    Risposta da 178.63.100.131: byte=32 durata=38ms TTL=53
    Risposta da 178.63.100.131: byte=32 durata=37ms TTL=53
    Statistiche Ping per 178.63.100.131:
        Pacchetti: Trasmessi = 4, Ricevuti = 4,
        Persi = 0 (0% persi),
    Tempo approssimativo percorsi andata/ritorno in millisecondi:
        Minimo = 37ms, Massimo =  38ms, Medio =  37ms
    C:\Users\Davide>tracert xsimulator.net
    Traccia instradamento verso xsimulator.net [178.63.100.131]
    su un massimo di 30 punti di passaggio:
      1    <1 ms    <1 ms    <1 ms  192.168.1.254
      2     5 ms     5 ms     5 ms  static-213-205-52-57.clienti.tiscali.it [213.205.52.57]
      3     6 ms     5 ms     5 ms  static-213-205-63-17.clienti.tiscali.it [213.205.63.17]
      4    11 ms    11 ms    11 ms  static-213-205-13-133.clienti.tiscali.it [213.205.13.133]
      5    26 ms    22 ms    23 ms  static-94-32-135-246.clienti.tiscali.it [94.32.135.246]
      6    24 ms    23 ms    23 ms  static-94-32-135-181.clienti.tiscali.it [94.32.135.181]
      7    23 ms    58 ms    22 ms  ae3-300.cr0-trn3.ip4.gtt.net [77.67.82.229]
      8    33 ms    32 ms    33 ms  xe-3-1-0.cr8-fra2.ip4.gtt.net [141.136.110.69]
      9    33 ms    33 ms    32 ms  hetzner-online-gw.ip4.gtt.net [77.67.76.142]
    10    37 ms    37 ms    37 ms  core21.hetzner.de [213.239.245.217]
    11    37 ms    37 ms    37 ms  ex9k2.rz12.hetzner.de [213.239.229.242]
    12    37 ms    37 ms    38 ms  xsimulator.net [178.63.100.131]
    Traccia completata.
  13. Blame73
    8,315Coins
    It always takes about 6 seconds to open a thread or the recent/new posts, while before it was almost immediate.
  14. Blame73
    8,315Coins
    I don't know if you changed anything @RaceRay but tonight is even worse, seems like I got a 33.6 modem
  15. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    mine is extremely slow today in the uk. it took 30 seconds or so to open my inbox on a 60mb conection and at home now on 150mb i would say pages are taking 5-10 seconds to load. was slow over christmas too but not as bad as today
  16. Blame73
    8,315Coins
    @RaceRay I wanted to tell you is now working fine. Last 2/3 days I had no problem at all
  17. RaceRay
    Hamburg, Germany
    23,892Coins
    Thanks, i am glad to hear:)
  18. Rastus
    Sydney Australia
    11,518Coins
    @RaceRay Same here more or less back to normal, although last time I checked still appears to be hopping through the US, Britain, France etc. really is the world wide web LOL
  19. Blame73
    8,315Coins
    @RaceRay
    Since two/three days it's really slow again
  20. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    It's been slow over the last couple of days for me too. (UK)
