Support of SNC6 with same port
Discussion in 'SimTools DIY Version' started by momo57, Jan 9, 2017.
  1. momo57
    momo57 New Member
    Paris
    312Coins
    SCN6
    Hello.
    I have downloaded your new tool, but it seems that it does not support 2x SNC6 running on the same COM port (with a different id)
    Is there anyway to bypass this limitation?
    Kind regards
  2. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    I didnt think you could do that with the old software either. i was told one actuator per com port
  3. momo57
    momo57 New Member
    Paris
    312Coins
    SCN6
    Yes, that's true...
    That's why i was not using this tool.
    I was hoping this limitation was removed on the new 2.0 version...
  4. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    Is it not easier to use 2 com ports and then use the software. the software itself is very easy to use so probably worth connecting seperatly
  5. momo57
    momo57 New Member
    Paris
    312Coins
    SCN6
    Yes, but that requires additionnal hardware that I don't have currently.. (usb to com convertor)
    around 100$ :/
    While my current conf is working with several other tool (logykal, etc..)
  6. crammy
    Fabrication
    essex
    4,634Coins
    SCN6, 4DOF
    No problem mate. i got mine from ebay for about £12 which is probably about 15 euros. they worked perfectly
  7. yobuddy
    51,535Coins
    It's reasonable to ask for 2 scn per adapter and it will be looked into.
    I'm just waiting for some scn test equipment to arrive.
    No eta on the new interface plugin thou.
  8. siegfriedricher
    siegfriedricher New Member Gold Contributor
    Le Lamentin
    87Coins
    SCN6
    I have the same problem. 2 SCN one port with 2 ID. Is it possible to upgrade in this way ? What do you think about that ?
  9. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    Is this what you're talking about guys ?
  10. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    I got the same problem. One converter, one USB. Funny thing I was not aware it is worth to upgrade till I came back to Assetto and found it very jerky. iR for so many years was no problem via one converter. Then I just a bit by accident bought Simtools 2.0 and found I needed another converter. So I bought another one.
  11. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
  12. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    Hey Yobuddy, I am also really interested by this . I had in ming a gseat with 50 mm snc5 . I found two on ebay very cheap and bought them already
    unfortunately, I found out later I was short of one interface. a simple solution would be those 2 snc5 on one com port. I am glad that you are working on a way to achieve this .
  13. yobuddy
    51,535Coins
    Just so you guys know.
    The reason SimTools only supports one SCN per adapter is that some cheep adapters cant get up to full speed with 2 scn's attached. And since the adapters are so cheep, why not just use 2 and have a better sim.
    I still have not received any hardware yet, but will look at it once some hardware gets here!
    Take care guys!
  14. Marin
    Marin New Member
    - 50Coins
    Does the latest simtool update support 2 SNC 6 on the same com port?
    Thank you for your feedback
  15. yobuddy
    51,535Coins
    Yes :thumbs
