News SimTools 2.0 Question and Answer
Discussion in 'News' started by yobuddy, Feb 29, 2016.
Thread Status:
Not open for further replies.
  1. MPG
    MPG New Member Gold Contributor
    Netherlands
    57Coins
    Yes, it works
    Thank you very much.
  2. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,261Coins
    A couple quick questions.
    If you wanted to stay on 1.3 for dash support (For things like my wind simulator)
    Is 1.3 still available? and will the new plugins work with 1.3? or is 1.3 deprecated now?
  3. bruce stephen
    general contractor
    michigan
    9,115Coins
    Yes 1.3 is still available. The plugins are not compatible with each other.
  4. Blame73
    Blame73 Well-Known Member
    8,304Coins
    I just don't get why everybody's buying licenses now and they got the codes. I bought it this morning and don't even got an answer...
  5. George Dobransky
    Hungary
    - 43Coins
    Bad news about Elite Dangerous is not going with that plugin...
    with joystick plugin also not good 'coz no smoothing in V2
    as before.
    Cheers
  6. spyderwash
    spyderwash genesy sim
    italy varese
    - 125Coins
    2DOF, 3DOF, Arduino
    I installed on another PC and everything works
  7. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    I can't find the information in first post - is something changed in GameDash compared to 1.3 version? Or is it the same?
  8. Historiker
    9,208Coins
    Gamedash is not implemented in the free version of Simtools 2.0. It is a feature that will soon be available in the Entertainment and Pro versions.
  9. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,238Coins
    Same on my side. Elite dangerous plugin for V2 doesn't work ! :-(
  10. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    hello
    Below the picture my current settings, this worked perfectly with simtools1.3
    But not with simtools 2.0
    am used thanos board
    thanks
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    @misoswan add the axis as Axis1a Axis2a etc.
  12. prodigy
    Croatia
    6,698Coins
    I know, I am just asking if there is something changed in Gamedash from 1.3 to 2.0 now when it comes with paid version. New functions or something..
  13. bruce stephen
    general contractor
    michigan
    9,115Coins
    Gamedash works the same with V2.0 @prodigy. If you are using @SilentChill fan code it will work the same.
    Edit sry Plus enhancements.
  14. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    [Quote = "bruce Stephen, post: 121.999, člen: 17503"] [user = 10681] @misoswan [/ USER] přidejte osu jako Axis1a Axis2a etc [/ quote].
    like this ? not work ..:(
  15. bruce stephen
    general contractor
    michigan
    9,115Coins
    @misoswan
    AB<Axis1a><Axis2a><Axis3a>
    Try this;)
  16. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    SORRY
    solved!!!!!!!!!!!! thanks
  17. f1iceman
    517Coins
    Thanks for confirmation i thought it was
    I can not wait to try the 6 channel car amp way.
  18. misoswan
    1,032Coins
    3DOF, Arduino, JRK
  19. yobuddy
    51,009Coins
    Yes, It can support up to 3 output interfaces now!
    Its a lot more refined/polished with a few bug fixes.
  20. Meawto
    Meawto Sorry for bad English ;'(
    Thailand
    - 336Coins
    if i buy "pro" for make motion plathfrom and race gauge sell.
    dose my customers need to pay 69.99$ for program ? @yobuddy
Thread Status:
