Simtools 2.0 Registration help needed
Discussion in 'SimTools DIY Version' started by Tim McGuire, Jan 10, 2017.
  1. Tim McGuire
    Canada
    2,221Coins
    3DOF, DC motor
    Hey guys, quick question.
    For some reason I can't get the SimTools_Registration.exe application to work. I've tried uninstalling and reinstalling, as well as turning firewall and antivirus off. Anyone else have this issue?
    edit: administrator permissions also don't help
    edit edit: Instead of "not working" I should have specified that it crashes upon trying to open it.
  2. yobuddy
    51,567Coins
    @George Dobransky,
    I can't seem to re-create your problem.
    but I'll keep looking.
    @Tim McGuire ,
    what happens when you launch "SimTools_Registration.exe"?
    thx guy's!
  3. Tim McGuire
    Canada
    2,221Coins
    3DOF, DC motor
    Hey, thanks for the reply :)
    When I launch the program, the loading bar will get about 1/6 of of the way across and then windows will throw an error. It all happens in a fraction of a second.
  4. yobuddy
    51,567Coins
    @Tim McGuire ,
    Are you installing 2.0 on a machine that had 1.3 on it?
    Did you fully remove 1.3 from this PC?
  5. Historiker
    9,205Coins
    @Tim McGuire also make sure that you do not have Simtools running when you try to use the registration tool.
  6. Tim McGuire
    Canada
    2,221Coins
    3DOF, DC motor
    It originally had 1.3 on it. I installed 2.0 on the first go-around without removing 1.3, but then I uninstalled both completely, and reinstalled 2.0 only. Are there any other simtools files that an uninstall wouldn't wipe? I can give it another go
  7. yobuddy
    51,567Coins
    As long as you answer yes to "Remove old Settings and Files?" during the un-installation process you should be ok.
    Do you know if you did that buddy?
  8. Historiker
    9,205Coins
    @Tim McGuire you might check C:\Users\[you]\AppData\Local for the Simtools folders and manually delete them.
  9. yobuddy
    51,567Coins
    @Tim McGuire ,
    please try this buddy,
    1) Removed all copies of SimTools.
    2) Manually delete the folders if they are found.
    3) Reinstall SimTools 2.0
  10. Tim McGuire
    Canada
    2,221Coins
    3DOF, DC motor
    @yobuddy, @Historiker
    I uninstalled both versions and checked the appdata, then reinstalled 2.0, the crash is still happening unfortunately :/
  11. Meawto
    Meawto Sorry for bad English ;'(
    Thailand
    - 336Coins
    @yobuddy is there any gamedash update for two or more arduino support ?
  12. yobuddy
    51,567Coins
    Very strange @Tim McGuire ,
    Would you mind reinstalling .net to make sure its not a corrupted .net installation?
    Also are you trying to register a free or paid for key?
    I can issue you a refund at any time if need be.
  13. Historiker
    9,205Coins
  14. Tim McGuire
    Canada
    2,221Coins
    3DOF, DC motor
    I'll give that a try and report back once I'm done. I registered for a Professional License. I'm sure I'll get it working eventually, so hopefully no refund will be necessary :p
    I'm on win10 64 bit
    154,028Coins
    +11,165 / 57 / -2
    Best to start a separate thread and post pictures of your settings.
  16. yobuddy
    51,567Coins
    @Tim McGuire ,
    I'll do everything I can to help you buddy!
  17. Tim McGuire
    Canada
    2,221Coins
    3DOF, DC motor
    Much appreciated! I'm in no great rush, so don't go out of your way, I'm sure it must be something strange on my end.
    I ran a .NET framework repair, sadly it didn't change anything
  18. Historiker
    9,205Coins
  19. Tim McGuire
    Canada
    2,221Coins
    3DOF, DC motor
    Would the registration program dump any logfiles anywhere that would be of use to look at?
  20. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    Hello
    Is there a way to keep or backup existant profiles ?
    what about 2 separate PC? do we have to remove fist gamemanager (gaming PC) and game engine on the second PC?
    do we have to uninstall gamedash?
    thanks
