SimTools + Arduino 2DOF acting weird
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by nihkiruks, Jan 10, 2017.
  1. nihkiruks
    nihkiruks New Member Gold Contributor
    Ukraine
    239Coins
    Hey guys,
    Skipping the introduction, I'm trying to setup a 2DOF arduino sim here in Ukraine.
    The problem is: in SMC3 it works perfectly. All the tests for both motors are passing and I'm getting perfect sin on it.
    When I'm trying SimTools Output Testing (and Live for Speed as well) I'm getting extremely strange behavior from the sim. See pic 2 and 3. Basically, with the shift change it tries to make me hit the steering wheel with my head..
    Within the Output Testing I've tried to move slider all the way to the right and then to the left as smooth as possible.
    Any advise will be appreciated.
    Thanks in advance!
    Sergey.
  2. Historiker
    9,205Coins
    Hi Nihkiruks, exit SMC Utility before using Simtools. The utility takes control of the motors causing errors in Simtools. Use the SMC3 utility only for adjusting your motors.
  3. nihkiruks
    Ukraine
    239Coins
    SMC setup to pass the data it's getting from SimTools to the sim so I can see what is actually being sent there. Without SMC it acts exactly the same way but I just don't have graphs :)
    Any clues?
  4. nihkiruks
    Ukraine
    239Coins
    Tried this, also downloaded recent version of SimTools. No luck. :(
    153,938Coins
    +11,158 / 57 / -2
    Please post clear pictures of all your SMC3 and SimTools settings.
  6. nihkiruks
    Ukraine
    239Coins
    Not sure what you mean by "clear" but here they are. Let me know if you need more info.
    Also, is there any debug mode in SimTools?
  7. nihkiruks
    Ukraine
    239Coins
    And two more pics where you can see the difference between 49% and 50% roll.
  8. nihkiruks
    Ukraine
    239Coins
    And the 0 level is about 50% down...
  9. nihkiruks
    Ukraine
    239Coins
    153,938Coins
    +11,158 / 57 / -2
  11. nihkiruks
    Ukraine
    239Coins
    Negative. Using SimTools 2.0 PRO. The bug is still there. I've read it was fixed so didn't paid much attention to it but when I've changed time/date format to from English (United States) to English (Europe) it got my problem fixed.
    Btw, how to report it back to developers?
    153,938Coins
    +11,158 / 57 / -2
    You can flag the developer like this @yobuddy, that way he will get an auto notification of the post.
  13. nihkiruks
    Ukraine
    239Coins
    Thanks! I assume you just got his attention :)
    153,938Coins
    +11,158 / 57 / -2
    Indeed!
  15. yobuddy
    51,543Coins
    @nihkiruks
    But I use English (United States)?
  16. nihkiruks
    Ukraine
    239Coins
    Have no idea why. I can play with it tonight to find more symptoms. I'm running Windows 10 RUSSIAN with English MUI on top of it.
  17. yobuddy
    51,543Coins
  18. nihkiruks
    Ukraine
    239Coins
    @yobuddy Here's what I got. Is there anything I can do to help you to troubleshoot this?
  19. Lorien31
    Lorien31 Member Gold Contributor
    IT System Specialist
    140Coins
    Good to know, i am on the way to installing sim tools 2 as well.
