License activation problem
Discussion in 'SimTools DIY Version' started by stelian78, Jan 11, 2017.
  1. stelian78
    stelian78 New Member Gold Contributor
    - 383Coins
    I'm having a really big issue with the activation. I've entered my key, says it's well and activated, then when trying to start up Manager and Engine, I get the following message:
    "There seems to be a problem with your PC's Date & Time.
    Please click 'Check License' within the registration app to correct the problem."
    I've checked both windows and bios clocks, I've re-checked the license a bunch of times.
    Now I really need some help.
    153,992Coins
    +11,162 / 57 / -2
  3. Pit
    30,510Coins
    @yobuddy will get in touch with you ASAP, meanwhile you could check if you had run the registration with admin privileges...and check your computer if set to the right time zone
  4. stelian78
    - 383Coins
    I'll try that asap. It's running on Windows 10 btw, with all the updates.
  5. yobuddy
    51,564Coins
    hi @stelian78,
    yes, will you please make sure your pc clock is set to the right time zone and that it is correct.
    Is anything running that may be interfering with communications to SimTools.us during registration?
    I know we can figure it out.
  6. stelian78
    - 383Coins
    No joy.
    - adminstrator-ed all the exe-s
    - firewall OFF
    - time zone automatically UTC +02:00, which is correct
    - time synced successfully to the internet
    Any logs I could give you?
  7. yobuddy
    51,564Coins
    Can you send me one of the license files found at:
    "C:\Users\(your user name)\AppData\Local\SimTools_License"
    send to Dustin@ SimTools.us.
    Where are you located buddy?
  8. stelian78
    - 383Coins
    E-mail sent, location: Romania.
  9. yobuddy
    51,564Coins
    Could you please try this?
    Set your region and language for the pc to English (United States)
    Then open the license app and press "Check License".
    Then try to launch the Game Engine and Manager.
    Let me know how it goes buddy.
  10. stelian78
    - 383Coins
    That was it! We've got output, now time for the axes setup..
  11. yobuddy
    51,564Coins
    great @stelian78,
    I will see what I can do to fix this error.
    but I'm glad we got it working for now buddy!
  12. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    Hey guys, I have the similar issue but my pc has had times where i had to reformat the drive several times in this past year.
    well it has happened again today and as im installing all the software and updates im going through the motions. i have my license for sim tools on a separate drive and go to put the key in and i read that i have no more activation left ? im not sure where i went wrong . i have two number the simtools key code and activation key code. ether way it isnt seeming to work for me. any ideas?
  13. noorbeast
    153,992Coins
    +11,162 / 57 / -2
    As SimTools licensing is handled independently you will need to use the contact form here: https://simtools.us/contact-us/
