Finished - compact 3 DOF with traction loss
Discussion in 'DIY Motion Simulator Projects' started by Robdog, Jan 12, 2017.
  1. Robdog
    Robdog Member
    Newcastle, Australia
    104Coins
    3DOF, JRK
    It started out as a 2 DOF sim that could sit in front of my desk and then it grew a heave axis followed by traction loss. Each addition has made a huge difference to the feel of the sim and I am would not want a sim without any of the axes.
    I have added a homemade shifter, button box and a hand brake along the way too. I need to thank everyone on the forum for sharing their ideas and designs. Nothing on my rig is an original idea, everything has been shamelessly copied with maybe the odd tweak.
    My next investment will be a rift, after that who knows.
    • Like Like x 17
  2. Stealthelius
    Stealthelius Member Gold Contributor
    Office Clerk
    Rome, Italy
    96Coins
    Nice simulator @Robdog and very nice motors :thumbs
  3. SilentChill
    20,591Coins
    Nice work well done :thumbs
    Edit: any videos ???
  4. My.stAr
    My.stAr Active Member
    Engineer
    1,064Coins
    DC motor
    A well build rig:thumbs
    Maybe a stupid question, but i can't identify what the second motor in the back is doing?! Is it there for heave?
  5. MarkusB
    4,215Coins
    The motors look like these: https://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html
    If so, it depends on the gear box. The default one with 25:1 (which seems to be used here) may not suited to lift an entire rig, but the 50:1 or 60:1 probably are.
    And the motors used in the other thread in which you asked the same question an hour ago are definitely strong enough. :)
  6. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,761Coins
    DC motor, Arduino
    Beau travail.
    Cependant une chose me choque dans la réalisation. De par la complexité de la cinématique d'un système bielle-manivelle, la symétrie des mouvements à droite et à gauche de l'axe de roulis du simulateur n'est pas assuré. Pour ce faire il faut respecter des règles que j'ai évoqué dans ce sujet :
    https://www.xsimulator.net/communit...ng-tutorial-3dof-heave-axis.9249/#post-122634
    Good work.
    However one thing shocks me in realization. Due to the complexity of the kinematics of a rod-crank system, the symmetry of the movements to the right and to the left of the roll axis of the simulator is not assured. To do this, you must respect the rules that I have mentioned in this subject.
  7. Robdog
    Robdog Member
    104Coins
    3DOF, JRK
    The motor in the middle is for heave , the one on the right is for traction loss.
    All the motors are from Motion Dynamics and are 200W with 25:1 gearboxes. The heave is assisted with a spring from a chair tilt mechanism, it runs a bit hot when the weather is hot so I have fitted a cooling fan. It doesn't seem to struggle with the heave, maybe that's because I am a light weight.
    I will try post a video over the weekend.
  8. Robdog
    Robdog Member
    104Coins
    3DOF, JRK
    I haven't read your post yet, will have a look. I have not experienced problems with symmetry, the rig is very solid and responds well to all movements.
  9. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    Nice job @Robdog ...
    Is this elbow is rotating ? Is this a compensation spring from an office chair ?
    more details please ... :thumbs
    Thanks for sharing good ideas ...
    • Dislike Dislike x 1
  10. Robdog
    Robdog Member
    104Coins
    3DOF, JRK
    The elbow is connected to an office chair tilt mechanism so the spring helps support it. I tried to upload a video of it working but it is a .MOV file and I can't upload it. Any idea how I get around that?
  11. stevemontuno
    stevemontuno Active Member
    1,461Coins
    Stick it on Youtube and post a link up .
  12. speedy
    Alexandria , Egypt
    7,943Coins
    Thanks for the effort ... Youtube accepts any kind of video format ... upload and just copy it's given URL and paste it here using this button to past the video URL correctly .
  13. dynt66
    dynt66 New Member
    cyprus
    279Coins
    Would love to see a video of this all working also.
  14. speedy
    Alexandria , Egypt
    7,943Coins
  15. Robdog
    Robdog Member
    104Coins
    3DOF, JRK
    Some videos showing the rig and the heave detail. Track is Brands Hatch, nice and bumpy.
    • Like Like x 9
    • Winner Winner x 4
  16. Stealthelius
    Office Clerk
    Rome, Italy
    96Coins
    Hi @Robdog. What about the noise of the motors ? I have a pair of Wiper motor and them are too noisy.
  17. RacingMat
    21,047Coins
    @Stealthelius : if the motors are driven by PWM below 20 kHz, they are noisy
    what driver are you using? motomonster can be tweaked to ultrasonic PWM
  18. Robdog
    Robdog Member
    104Coins
    3DOF, JRK
    The motors are not noisy at all, the only noise I have is a rattle from the rod ends when the rods move.
  19. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    Man... thanks for the idea of traction loss ;)
  20. speedy
    Alexandria , Egypt
    7,943Coins
    Yeh I keep coming back and look again at the simple and effective concept ...
    Good job man .:thumbs
