Over ambitious new user needs lofty ideas rained in! ME :D Full rotation gimbal with 6 dof stewart
Discussion in 'New users start here - FAQ' started by D_Burto_1_BTW, Jan 12, 2017.
  1. D_Burto_1_BTW
    D_Burto_1_BTW New Member
    Custom metal fabrication and prototyping
    Adelaide, Australia
    294Coins
    Hello everybody.
    I'm dburto and i'm a new user. My work background is in metal fabrication and I do a lot of CAD and designing in my job as well. My father whom i work with is a fitter/machinist/toolmaker has a long history of machinery setup and maintenance in a wide variety of areas.
    I got myself semi-acclimatized to simtools and sketchup and used the pre-made 3-DOF model to test out the software, game, etc. It took a while but ended up working very well.
    I then drew up a 3-DOF full rotation rig to see how it would work with simtools. I can control the rig but have not tried full rotation on a flight sim to see if it will continue the roll/pitch/yaw. I have no idea if that will work. Someone please tell me if they have tried so i dont have to buy a flight sim to test my hypothesis.
    Ive drawn up a 6-DOF or 9-DOF simulator (not sure which one to call it) and i want want to make it work on sketchup (IF I CAN) before i build a scale model i can fit a doll in.
    It is essentially a 6-DOF simulator mounted inside a 3 axis full rotation gimbal. Can anyone help me make it work. MY codefu is very weak but my weld is strong.
    Please help. :D
    Ive seen a couple of chaps on here have tried this but they seem to have stalled. Maybe a collaboration is in order to get this done.
    Cheers and once again hello to all! :D
  2. D_Burto_1_BTW
    Adelaide, Australia
    294Coins
    If someone could tell me how to upload my drawing it would be great as well. Its in sketchup 2016 32-bit
    152,427Coins
    +11,077 / 56 / -2
    If you zip the file and it is not too big then you can use the upload button to attach it to a post.
    If it is a huge file then you would likely need to use Google Drive and add a link in the post.
  4. D_Burto_1_BTW
    Adelaide, Australia
    294Coins
    Here is a link.
    drive.google.com/file/d/0B278VzuqQXt4Tm9FOFJQYWw1Rk0/view?usp=sharing
  5. D_Burto_1_BTW
    Adelaide, Australia
    294Coins
    Cheers for the help noorbeast! :D
  6. Daguru
    Kitchen installer
    Wales uk
    467Coins
    Motion platform
  7. D_Burto_1_BTW
    Adelaide, Australia
    294Coins
    Cheers Daguru! :D
  8. Daguru
    Kitchen installer
    Wales uk
    467Coins
    Motion platform
    holy crap:eek: !!! good luck with your project :popcorn
  9. obobo
    obobo Active Member
    1,323Coins
    Pay attention to the head when the simulator will be head down
  10. D_Burto_1_BTW
    Adelaide, Australia
    294Coins
    obobo - so i should design it to keep a persons head as close to the centre of rotation as possible?
  11. obobo
    obobo Active Member
    1,323Coins
    Yes I suspect that the goal is to leave the user closer to the center of rotation.
    But it will be necessary to think of a system of maintenance very adjusted to avoid that one can fall.
    And provide a bucket for the sick in transport
    But the structure will be adapted to all sizes
  12. D_Burto_1_BTW
    Adelaide, Australia
    294Coins
