News X-Plane 11 free demo is now available
Discussion in 'X-Plane' started by noorbeast, Nov 25, 2016.
  1. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    I do not know I've tried various combinations
  2. Lorien31
    Lorien31 Member Gold Contributor
    IT System Specialist
    140Coins
    I'm flying quite often in xplane11, although the beta 5 is killing my fps.
    So if i get time next weekend i can try to connect my racing motion rig to the plugin, and check if i get it to work.
  3. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    v2 is working properly in x plane 11
    • Informative Informative x 3
  4. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    What is your graphic card for running xp11 with VR ?
  5. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    hello
    for my
    gtx 780amp
  6. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    ok thanks and do run it with low graphic option ?
  7. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    how fps you got ?
  8. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    setup medium 30 fps .need time for beta flyinside and beta x plane 11 :) next plan maybe x plane 11 native VR :)
    and my fps in dcs world all hight setup and 2.5 pixel 30-45 fps
  9. Adrianstealth
    Adrianstealth Active Member
    director
    england
    160Coins
    SCN6, 4DOF
    Hi
    I'm considering buying Xplane 11 , is this an X-sim plug-in ?
    it will work like the DCS world one does ??
    also is there anyway to get vibration feed (like simvibe )
  10. value1
    15,077Coins
    Try this with the X-Plane 10 plugin.
  11. lysa elec
    lysa elec LYSA ELEC
    - 26Coins
    when I am on simtools 2 in test mode the roll axis works (slider to the left I lean to the left) but on x plane the Rool is investigated
    What’s happen?
    thanks
    152,559Coins
    +11,087 / 56 / -2
    I am guessing you mean inverted, if so it is your Dir box in Axis Assignment that determines which way roll moves.
  13. Simsalabim
    Simsalabim New Member
    3Coins
    First tests are not good with new setup with Xplane 11.35:
    Simtools V2.4 Game Engine quits after few minutes, in fact randomly.
    Installed on vanilla windows 1903, same PC with Xplane on it.
    PC is i7-8700/16GB/1080Ti
    Motion platform not even connected nor any drivers running.
    Will try in networked mode.
    Has anybody stable solution, since not many comments here, and plugin is not very recent it seems.
  14. value1
    15,077Coins
    Hmm, I know that somewhere on one of my harddisks I have a proper X11 plugin buried, one that properly identifies the data sent by xplane.
    I will dig it up sometimes!
  15. value1
    15,077Coins
  16. Simsalabim
    3Coins
    strangely I get seemingly no pitch motion, it seems pitching the airplane give me rather more roll. Though testing the pitch in simtools seems fine on the platform.
    Any ideas?
  17. Simsalabim
    3Coins
    BTW, do you have to reinstall the plugin every time you want to change the tuning values?
  18. noorbeast
    152,559Coins
    +11,087 / 56 / -2
