News SimTools 2.0 Question and Answer
Discussion in 'News' started by yobuddy, Feb 29, 2016.
Thread Status:
Not open for further replies.
  1. bruce stephen
    general contractor
    michigan
    9,115Coins
    From your explanation pulling the dongle didnt help. Is it possible to plug your machine into your network/internet directly with a cable for troubleshooting purposes. Then do clean restart. Then take a screen shot.
  2. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    And make sure to Exit both applications from here too ... right click .
  3. MWB
    MWB Drive it like you stole it!!
    Commissioning Engineer
    U.K.
    424Coins
    2DOF, DC motor, Arduino, Motion platform, 4DOF, 6DOF
    Ok IP has changed to 192.168.1.71 on both
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    Now enter that ip into both apps. Don't exit or restart your PC or either app. As soon as you save is when it should connect. Let us know.........
  5. MWB
    U.K.
    424Coins
    Hit save on both, didn't connect!
  6. bruce stephen
    general contractor
    michigan
    9,115Coins
    I'm plum out of ideas this may be a job for......Superman. Or one of those other superheroes.........
  7. MWB
    U.K.
    424Coins
    Me to bud! I thinking I may well need to go back to 1.3 it sucks! Was really looking forward to trying out the new Simtools :( thanks for all you're help! :thumbs
    152,559Coins
    +11,087 / 56 / -2
    There has been a change in how SimTools interfaces with JRKs, the upside being how much more responsive they are, the down side as you have found out is that you can't run the JRK config utility and SimTools at the same time, as they are using the same API.
    152,559Coins
    +11,087 / 56 / -2
    There was considerable refinement and testing done around filters, some games like AC were more problematic than others, so I guess there is the possibility of further development.
  10. speedy
    Alexandria , Egypt
    7,944Coins
    152,559Coins
    +11,087 / 56 / -2
    Your frustration is understandable and I know it is a pain, but can you please have another go starting from scratch.
    1. Unpatch any patched games.
    2. Make sure SimTools is not running.
    3. Uninstall SimTools, accepting remove all files.
    3. To be sure go to C:\Users\YOU_USER_NAME\AppData\Local and delete any SimTools folders, they would be called SimTools and the second folder would be SimTools_License.
    4. Go to C:\Program Files (x86) and check if there is a folder called SimTools, if there is delete it.
    5. Uninstall LFS, once done make sure the LFS is also gone, if not delete it.
    6. Reboot.
    7. Download and install the latest .NET and install: https://www.microsoft.com/net/download
    8. Reinstall SimTools 2.0 (perhaps even consider downloading it again to be sure it is not corrupted in any way), leave it as Demo Mode to start with, you can register it later.
    9. Before adding any plugins or patching or doing any configuration open Game Manager and see if it is green and says Connected.
    10. If all is good set up your Interface Settings and Axis Assignments, then test in OutPut Testing.
    11. Reinstall LFS and drive it for a couple of laps.
    12. Patch LFS for motion and test.
    13. Run SimTools Registration as a normal user from the menu.
    14. If this fails at any step let us know which one, it may help identify what is causing the problem.
    • Useful Useful x 3
  12. speedy
    Alexandria , Egypt
    7,944Coins
    The problem is that you may still have a previously used and a pre configured UDP port and it's not free for the new v2.0 installation ... maybe a windows 10 issue as I'm getting used to hear :(
    I've previewed your photos closely and you had it buddy just one click away ...
    you should go and continue with the messages that says Unreachable network ...
    Yes ... These will reset the previous installation stuck network addresses and UDP ports and leave you free to go back to them again ... And use only the Game Manager to change the IP back ... just use the 125.0.0.1 first ... continue with error messages ... go back to 127.0.0.1 ... Close and Exit then on every change .
    Please, Try it again before the clean installation as you won't loose much time on this step .
  13. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    @MWB - Might be a long shot, but I wonder if your "Local" network is locked down. It appears you can't send traffic locally which is really odd.
    Open up File Explorer, go to Windows then System32 and scroll down to find cmd.exe. Right click this and run as administrator.
    Once the CMD line opens, type this to kill your firewall across all profiles (Public / Home)
    NetSh Advfirewall set allprofiles state off.
    Then fire up Game Engine and Manager again.
    If no joy, to restore your firewall, just do:
    NetSh Advfirewall set allprofiles state on
    Failing that, I would see if your Anti-Virus has some how marked SimTools as "rogue" and is stopping any communication from it. It should not, it's perfectly safe, but if your AV has some setting to treat "new" as suspicious, it could be an avenue...
  14. speedy
    Alexandria , Egypt
    7,944Coins
    @MWB @bruce stephen ... Sure you have a progress in this issue :thumbs...
    see the first photo the Game Engine was not connected to the background port "Red Rectangle" ...
    At the second one it is connected "Green Rectangle" .
    @MWB You were just a click away ... do the same with the Game Manager .:thumbs
  15. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    i read somewhere we need different plugin ( simtool V2.0) ?
    I think you should add a separate download page for plugins working with simtool v2
    just my pov.
  16. Historiker
    9,208Coins
    There is a page dedicated to download of the v1.3 plugins and software instead. Easier to futureproof things that way. Especially since there will be no future plugins made for v1.3.
  17. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Hello everyone and congratulations for your work!
    A little question: When ready, how will the "Vibe" section work?
    Using a single PC will be able to instal a second sound card to interface with simtool, or I'll be necessary to use a "two PCs configuration" connected via Ethernet interface?:confused:
    Thank you!!!
    Ciao a tutti e grazie per il vostro lavoro!
    Una domanda: quando sarà pronta, come funzionerà la sezione "Vibe"?
    Utilizzando un singolo PC, sarà possibile installare una seconda scheda audio da interfacciare con SimTools, o sarà necessario utilizzare una configurazione con due PC connessi via interfaccia ethernet? :confused:
    Grazie!!!
  18. MWB
    U.K.
    424Coins
    Thanks @noorbeast
    I have followed this to the letter
    Downloaded Simtools again, got as far a 9.
    And it has not connected.
    Didn't install as administrator nor did I open it as administrator. Hope this help identify the problem. :thumbs
  19. MWB
    U.K.
    424Coins
    Thanks @speedy
    I had done the same with the Game Manager tried a couple of different combos and could not get it to work. Going to wait further instructions from @noorbeast :thumbs
  20. insanegr
    insanegr !N$@n€
    Athens
    16,724Coins
    @MWB 127.0.0.1 is the address used to establish an IP connection to the same machine or computer being used by the end-user.you are on a single pc configuration right? i don't think you have problems with the ip. probably your firewall is blocking Game Manager to communicate with Game Engine.you could give it a try on a other PC to see what happens there.
Thread Status:
