News SimTools 2.0 Question and Answer
Discussion in 'News' started by yobuddy, Feb 29, 2016.
Thread Status:
Not open for further replies.
  1. yobuddy
    51,524Coins
    @MWB,
    Somehow I missed why we started changing the ip addresses?
    Your on a single installation of SimTools 2.0 right?
  2. MWB
    MWB Drive it like you stole it!!
    Commissioning Engineer
    U.K.
    424Coins
    2DOF, DC motor, Arduino, Motion platform, 4DOF, 6DOF
    Yes
  3. yobuddy
    51,524Coins
    So no IP addresses changing is needed at all then.
    Both of them should be 127.0.0.1.
    Please set them back to these numbers and tell me what you get buddy.
    They should connect.
  4. bruce stephen
    general contractor
    michigan
    9,115Coins
    153,758Coins
    Just checking that in Game Engine under Tools the Manager IP is 127.0.0.1?
    I suspect something in your network configuration is messing with what is called localhost, which is 127.0.0.1.
    What specifically are you using for network connectivity, a dongle was mentioned, so what brand and model number.
    What happens if in your menu you search for cmd, open a command prompt and type this in it:
    ping localhost
    ping 127.0.0.1
    You could try this, but keep in mind we are asking you to modify your machine settings as SimTools is not really the issue, it just needs 127.0.0.1 properly defined:
    Go to %systemroot%\System32\drivers\etc
    Backup the hosts file
    Then open notepad with administrator rights.
    Navigate to the same folder and open the hosts file
    Make sure the first line after the # lines (comments) is 127.0.0.1 localhost and the second is ::1 localhost
    Then open cmd and run the command ipconfig /flushdns
    Restart SimTools.
  6. MWB
    U.K.
    424Coins
    I'm going to try this now!
  7. yobuddy
    51,524Coins
    Hi MWB,
    Will you open a command prompt and type "Ping 127.0.0.1" and see what you get?
    thx man.
  8. MWB
    U.K.
    424Coins
  9. yobuddy
    51,524Coins
    Are you blocking any ports on your pc by chance?
  10. MWB
    U.K.
    424Coins
    And this is what's in the host file
    But for some reason I can't change the IP in Manager or Engine, The IP is stuck on 192.168.1.71
  11. MWB
    U.K.
    424Coins
    Not that I'm aware of, how could I check?
    153,758Coins
    What is the next bit in the host file, it should be something like this:
    127.0.0.1 localhost
    127.0.0.1 localhost.localdomain
    255.255.255.255 broadcasthost
    ::1 localhost
    127.0.0.1 local
  13. MWB
    U.K.
    424Coins
    That's all of it!
  14. MWB
    U.K.
    424Coins
    Dongle is a Netgear genie N300 WRS wireless adapter.
    153,758Coins
    Two things you can try.
    1. Take out the dongle and use a cat cable to connect directly to your modem and check SimTools then, I am curious if the dongle itself messes with the hosts definitions.
    2. Open Notepad as admin and then the hosts file, add:
    127.0.0.1 localhost
    ::1 localhost
    127.0.0.1 local
    Save it.
    Then start and check SimTools.
  16. MWB
    U.K.
    424Coins
    Hi @noorbeast, I removed the dongle, no difference, I removed the cat cable, and after I rebooted, the correct IP is on both programs, but still no connection, can't modify the hosts file, because it says I don't have a administrator rights to do so!! Can't work out the to get round this!
  17. MWB
    U.K.
    424Coins
    @yobuddy @noorbeast
    Think I may go and get another hard drive tomorrow and start from scratch, load on windows and just the basick's for my sim rig because I don't think we are going to fix this, thanks for all your help, I'll let you know how I get on.
  18. noorbeast
    153,758Coins
    You need to run notepad as Admin to modify the hosts file.
    Search for notepad in your menu, right click on the menu and select Run As Administrator.
    Add the details supplied earlier and save the hosts file.
  19. MWB
    U.K.
    424Coins
    Hi @noorbeast
    I modified the host file, hope this is correct?
    Then run the IP config in cmd
    Tried Simtools as administrator and normally, didn't connect.
    Rebooted PC and tried again. Didn't connect :confused: And I've disabled all Firewalls and anti virus software!
    153,758Coins
    Don't use the # that makes it a comment, mod the file with just these:
    127.0.0.1 localhost
    ::1 localhost
    127.0.0.1 local
    Then run the cmd again.
Thread Status:
