Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. Historiker
    9,208Coins
    Axis testing is always using the default settings. :)
  2. Scotty1186
    Scotty1186 Member
    Usa
    148Coins
    Gotcha. I thought it was game specific. Thanks!
    152,105Coins
    +11,065 / 56 / -2
    No you can't use the 1.3 plugins, you will have to install the newly updated plugins for 2.0.
    Use the Plugin Updater in the SimTools folder found in your Windows menu.
    152,105Coins
    +11,065 / 56 / -2
    The updated plugins are here: https://www.xsimulator.net/community/forums/simtools-plugins.135/
    To install them use the Plugin Updater in the SimTools folder found in your Windows menu.
  5. maxx8888
    maxx8888 New Member Gold Contributor
    - 335Coins
    Hello
    If I assume the settings of version 1.3 in 2.0, I get no signals or movements on my 2DOF! I am using an arduino mega with serial link. If I then go back to version 1.3 everything works again normal!
    What am I doing wrong?
    thank you
  6. Blame73
    Blame73 Well-Known Member
    8,304Coins
    I think you are using v2 together with v1. 3.
    Remember you have to completely uninstall 1.3 and delete settings before installing 2.0.
    Back up previous settings if you want to (I did it just for reference)
  7. maxx8888
    - 335Coins
    I have deleted 1.3 before I have 2.0. I think all this was deleted. Then I installed 2.0 and the data for serial konoikation again registered. When I got the thing not to run, I've 2.0 again deleted and 1.3 installed. Went immediately again without problems.
    I bhab the same data registered at 2.0 as with my upper post in version 1.3! Are these possibly wrong at 2.0? Or must a code, name or whatever else be different?
  8. Blame73
    8,304Coins
    I don't know if using the tilde between axis is correct. Try deleting it
  9. SeatTime
    You have not defined the axises correctly - there are now an 'a' & 'b' group.
  10. Blame73
    8,304Coins
    It should be
    [A<Axis1a>][B<Axis2a>][C<Axis3a>]
  11. yobuddy
    51,030Coins
    @maxx8888 ,
    Try this buddy: "A<Axis1a>~B<Axis2a>~C<Axis3a>~"
    The 'a' tells it which axis asignments to use as we have 2 sets now.
  12. Blame73
    8,304Coins
    ~ replaces [] ?
  13. Wanegain
    Wanegain Active Member
    Bruxelles
    2,003Coins
    I have an issue when I press the Stop button : unhandled expection and then I have to close Game Manager and restart it.
  14. yobuddy
    51,030Coins
    @Wanegain,
    Is this a new problem?
    What was the last game plugin you installed?
    do you have the kart racing pro plugin installed?
  15. Wanegain
    Bruxelles
    2,003Coins
    I did not read this whole thread for saying it's new...
    I tried first before installing a plugin and it crashed. After that I installed AC, DiRT, GTL and Pcars plugins...
  16. yobuddy
    51,030Coins
    @Wanegain
    By new, I mean did you notice it start after installing a certain game plugin?
  17. maxx8888
    - 335Coins
    Do I have to rename the axes in the arduino software?
  18. yobuddy
    51,030Coins
    @maxx8888 ,
    No, the only difference is <Axis1> to <Axis1a>, thats all buddy.
  19. yobuddy
    51,030Coins
    I'm, sorry @moaale,
    I don't understand buddy.
  20. Blame73
    8,304Coins
    English/Spanish translation seems to be difficult.
    I think you're using the demo version, right?
    have you bought a professional license or asked for a free DIY license (in case you built your own rig and have your thread here)?
    https://www.xsimulator.net/request-diy-key-simtools/
