Simucube DIY thread
Discussion in 'Direct Drive Wheels' started by Nick Moxley, Jan 10, 2017.
  1. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    My God. What is in there? Mine is empty
  2. Pit
    30,498Coins
    you're asking seriously? lol
  3. obobo
    obobo Active Member
    1,323Coins
  4. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    it just looks like the box is full to the brim, and a lot of wiring. I really think mine is practically empty. Going to make my self look a dick, undo it, and it will look like that lol
  5. bruce stephen
    general contractor
    michigan
    9,115Coins
  6. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
  7. Pit
    30,498Coins
    @crammy clean work! So why you bought such a big case :p Joke aside, it's perfect. My wire is not done by myself, I bought the set from Ollie.
    PS: and you have the SimuCube which is pretty smaller
  8. bruce stephen
    general contractor
    michigan
    9,115Coins
    If you have access to a laser cutter or a CNC, there may be someone in your area that will cut things for a fee, you can create the same enclosure that Granite devices sells. They offer the files for download in 2d format here......https://granitedevices.com/wiki/SimuCUBE_technical_specifications
    Scroll down they should be the first two links, these are compatible with the mean well psu's.
  9. Nick Moxley
    Hey pit, may i ask a favor and have you blatantly label your build pics on this thread as an Argon build and NOT a Simucube, Believe it or not, if a DIY builder see's an argon build with the Rats nest of wires and dozens of components, He very well might get scared off, As i once did with the Old OSW setups.
  10. Nick Moxley
    or just torture yourself and make your own Custom box....:p That was a tedious build i tellz ya. :grin
  11. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    in hindsight i probably should of just purchased the small acrylic box. My cnc plasma will be set up at work in a couple of weeks, so when i make my new rig, i may make a smaller aluminium one with the link that @bruce stephen just posted
  12. Pit
    30,498Coins
    For me as a non native speaker hardly to understand lol, just to clear it out I do not own an Argon build. The former set from Ollie is "similar" to the SimuCube and can be driven with up to 4 IONIs AFAIR.
  13. Pit
    30,498Coins
  14. Nick Moxley
    Ah right...... Pre the SimuCube, I remember that now.....Ok sorry then, A slightly less confusing Argon build, but still a tad more complicated than the actual Cube.
  15. bruce stephen
    general contractor
    michigan
    9,115Coins
    @Nick Moxley that is an IONI-CUBE build. in between the argon and Simucube. it is basically the same as Simucube just not on one board. it can even run in simucube mode.;)
  16. Nick Moxley
    Yup and it needed a 2nd psu if i recall, and a Discovery board or something...... Big thanks to Granite for doing the cube....I can only imagine how many they've sold in the past year or so since the Indi campaign.
  17. bruce stephen
    general contractor
    michigan
    9,115Coins
  18. Blame73
    Blame73 Well-Known Member
    8,305Coins
    • Agree Agree x 3
  19. yobuddy
    51,224Coins
    I think an OSW area, under the "Motion simulator Hardware" section, makes sense.
    Let's see what René thinks.
    • Agree Agree x 6
  20. Pit
    30,498Coins
    @RaceRay it's your turn ;)
