News SimTools 2.0 Question and Answer
Discussion in 'News' started by yobuddy, Feb 29, 2016.
Thread Status:
Not open for further replies.
  1. MWB
    MWB Drive it like you stole it!!
    Commissioning Engineer
    U.K.
    424Coins
    2DOF, DC motor, Arduino, Motion platform, 4DOF, 6DOF
    Ok changed it, done all the same, didn't connect!
    152,541Coins
    +11,085 / 56 / -2
    Is that with a reboot with no dongle or cat cable plugged in?
    Edit - this should still be in the file
    # localhost name resolution is handled within DNS itself.
    # 127.0.0.1 localhost
    # ::1 localhost
    And if the edited file does not work the hosts file should be restored to the original configuration.
  3. MWB
    U.K.
    424Coins
    Hi @noorbeast #
    Yes I tried rebooting as well.
    So when edited it should look like this?
    # ::1 localhost
    127.0.0.1 localhost
    127.0.0.1 localhost.localdomain
    255.255.255.255 broadcasthost
    ::1 localhost
    127.0.0.1 local
    Thanks MWB
    152,541Coins
    +11,085 / 56 / -2
    Yes @MWB that is how it should look, but if that is not making a difference remove the following and flush to return the file to its original state:
    127.0.0.1 localhost
    ::1 localhost
    127.0.0.1 local
    Once that is done can you right click on your network connection and go to Open Network and Sharing Center.
    Under View your active networks click on the Connections link, then Properties in the window that opens.
    Highlight Internet Protocol version 4 and hit properties, and do the same for Internet Protocol version 6. Are both set to Obtail IP and DNS server Automatically?
  5. MWB
    U.K.
    424Coins
    Hi @noorbeast
    Just tried my dads PC, Windows 10 home
    Download it, installed it, didn't do any administrator stuff. And it connected first time
    :think
    Think I'm just going to rebuild my PC, my windows was an upgrade from 7 so maybe this is cocked stuff up!! :confused:
    152,541Coins
    +11,085 / 56 / -2
    Yes it sounds like something is confusing it between being localhost and its IP address. It is the machine, not SimTools that is the issue.
  7. MWB
    U.K.
    424Coins
    Yeah 100% agree that's it's no fault of Simtools, I would love to work through this and find the fault because it's good for the forum, but I want to get back to using my sim, and it shouldn't take long to rebuild! But thanks soooo much for everyone's help. I'll let you know how I get on.
  8. bruce stephen
    general contractor
    michigan
    9,115Coins
  9. MWB
    U.K.
    424Coins
    Hi All,
    I've installed Windows 10 Home 64 on a new SSD installed Simtools 2.0 and have connected Game Manager to Game Engine!!! I have no clue why it didn't work before, but thanks to all involved with your help especially!
    @bruce stephen @speedy @noorbeast @yobuddy
    Now I've just got to wait a couple of hours for my games to download through steam and I can patch a game!! Let's hope that go's a bit smoother!! :cheers
    • Winner Winner x 5
  10. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    Assigning forces to axis in SimTools ...
    - DOF 1 - DOF 2 - DOF 3 - ..... - DOF 6 are the main 6 forces "Degree Of Freedom" plus the Extra 1 ,2 ,3 forces as the game plugin provides them that could be assigned , reversed/added with different values for each Axis ...
    - Axis 1
    Axis 2
    Axis 3
    Axis 6
    are the actual available axis used for any simulator that can provide motion to it's platform with respect to their mechanical motion ...
    - Each Axis line of 6DOF's at the end will sum total gives its output to its specifically assigned motor in the interface settings ...
    - For Axis mechanical limitation its actual physical range can be limited by the Axis limiting tap ...
    - For the overall game behavior adjustments could be done via the main level in the Game Manager Profile Editor ... unless you need to change the behavior of a specific force you add zeros to its previously saved value in the tuning center so any new value will be smaller thus the simulator will act slower for that force only ...
    you can scale the DOF strength up/down per axis without losing details with smoothing it ... in three working arias :
    - [Normal] If you use 100% strength of any DOF force assigned with a 100% usage of the Axis movement ...
    SimTools will distribute that 100% strength over that 100% distance resulting of a 1:1 movement .
    - [Zoom In] If you use 50% strength of any DOF force assigned with 100% usage of the axis movement ...
    SimTools will distribute that 50% strength over that 100% distance resulting of a 1:2 movement [ stretched up movements over the required distance ] .
    - [Zoom Out] If you use 150% strength of any DOF force assigned with 100% usage of the axis movement ...
    SimTools will distribute that 150% strength over that 100% distance resulting of a 1.5:1 movement [ stretched down movements over the required distance ] .
    • Informative Informative x 3
  11. yobuddy
    51,186Coins
    Great Job MWB!!
    May to stick with it!
  12. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Just wanted to post a quick "Thank you" to everyone involved in making SimTools v2 and the associated Plugins.
    I finally managed to spend some time tuning my movement profiles under the new system and, well... WOW!!
    I was really concerned that tuning DiRT Rally to be "just right" again under V2 would take some time.
    I need not have been worried.
    The "On/Off" feature makes tuning and axis management soooo easy. Coupled with the new "Balanace/Capture/Off" in the tuning centre, I can concentrate on one force / axis without affecting the already stored values in Max Min for other values.
    It really is an awesome upgrade. DiRT Rally is bonkers now on V2. I am getting so much more motion from the bumps and undulations of the rally courses. Heave has had a complete re-vamp for this plugin and when the car slams down from a jump, boy does that ever get translated to the seat!
    I'll have to take a video of the new movement, it's incredible.
    Thanks again to everyone!! Loving it.
    • Like Like x 5
    • Agree Agree x 3
  13. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    @yobuddy or @speedy what is the difference in the axis tab of game engine between:
    AXIS TYPE : generic 2D standard or
    AXIS TYPE : generic basic
    thanks
  14. yobuddy
    51,186Coins
    The basic one has no filters buddy.
  15. RobertH
    RobertH Member Gold Contributor
    The Netherlands
    1Coins
    2DOF, SCN5
    Is there a new plugin for Automobilista?
  16. bruce stephen
    general contractor
    michigan
    9,115Coins
    Not for Simtools Version2.
  17. RobertH
    The Netherlands
    1Coins
    2DOF, SCN5
    Why not?
  18. bruce stephen
    general contractor
    michigan
    9,115Coins
    It hasn't been created. The version for v1.3 still works. I am not sure if @Boomslangnz the member that was kind enough to create the first version has plans to update it. Version 2 is still very new and updated resources may take some time in some cases.
  19. vsp19
    vsp19 keep Sim-Racing Gold Contributor
    170Coins
    2DOF, 3DOF, SCN6
    Hello SimTools V2 developer
    You really did a very good job !
    I have tested SimTools V2 against SimExpierence or Simcommander with my 2-Dof SCN6 Motion system.
    I feel much more accurate motion movement
    for me,
    SimTools V2 is much better than SimComander
    in resolution and imaging at IRacing and Dirt
    Thanks for the great implementation
    And please continue this way
  20. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    let me give my input on V2
    Pro installed on two pc.
    I tried iracing and asseto c. It feels smootheralmost out of the box with no major twicking. however , for me, V1.3 already very nice with some twicking.
    ONE bug : game engine need to restart if you exit iracing (or simply click on the game engine windows to rmind the program to be active)
    the same is seen in AC. However, it is more drastic it needs a complete restart (i did not investigate as much as in Iracing)
    thanks a lot to the developper forproviding this excellent program...
    I cant wait to try simdash and gamevibe (especially gamevibe as simvibe takes a lot of computer juice)
Thread Status:
