2DOF Wiper, compact seat mover
Discussion in 'DIY Motion Simulator Projects' started by guille, Jan 16, 2017.
  1. guille
    guille New Member
    IT Engineer
    Tarragona
    389Coins
    I've finally started my own seat mover. The main goals for this project are: it has to be cheap, and it has to be small (as in small footprint).
    So I bought the arduino and the motomonsters from deal extreme a year ago, I don't remember how much they costed. I bought two used wiper motors from a a shop here. I seems that everything in Tarragona, Spain is a lot more expensive than anywhere else, because they charge me 40€ for each motor.
    I've modified the motors for the ground isolation. It's a pity that I haven't remembered to make some pictures of that. Because It was very difficult (for me at least).
    I've got a Dell Z750P power supply capable of 62A, got it from an old server for free.
    And finally a guy bring me for free some square metals left over for free.
    I am making the frame without plans, and I am a novice welder, so this is what I've got for now.
    The Base:
    The seat holder
    Marriage of both parts:
    I am waiting for the connecting rods, but while waitnig I wanted to test movement. For that I've used the wiper frame that came with the motor.
  2. guille
    guille New Member
    IT Engineer
    Tarragona
    389Coins
    I've uploaded two videos of the frame:
  3. lilted86
    lilted86 Member
    Malaysia
    489Coins
    all the best for your project!..keep it up!
  4. guille
    guille New Member
    IT Engineer
    Tarragona
    389Coins
    Thank you
  5. guille
    guille New Member
    IT Engineer
    Tarragona
    389Coins
    While I'm waiting for the rods, I am thinking how to connect the wiper to the potentiometer, I am forced to use the same side as the lever because the wiper I have only have one side. This is what I think I could fabricate:
  6. Tomsix
    Tomsix Member
    Németország
    324Coins
  7. guille
    guille New Member
    IT Engineer
    Tarragona
    389Coins
    Thank you
  8. guille
    guille New Member
    IT Engineer
    Tarragona
    389Coins
    After a lot of testing, I realized that the motors are too weak, the connection from the motors to the seat are too weak too. For starters. Does anyone know where to buy two (12V) DC motors that have enough power. I am buying from Spain.
    151,620Coins
    +11,043 / 56 / -2
  10. guille
    guille New Member
    IT Engineer
    Tarragona
    389Coins
    Yes I did have a look at that post, but sadly the ebay sale has ended, and motiondynamics is from australia, but thank you for your post
    151,620Coins
    +11,043 / 56 / -2
    Motion Control Products are in the UK: http://motioncontrolproducts.com/
  12. guille
    guille New Member
    IT Engineer
    Tarragona
    389Coins
    Thank you very much, this:
    Model: 73ZYT-145-12-MCP4-62/1-BZ-GH1436 (12VDC, 135W, output speed 70RPM, 15Nm, gear ratio 62:1, bronze gears)
    Seems to be a good choice, what do you think?
  13. noorbeast
    151,620Coins
    +11,043 / 56 / -2
  14. guille
    guille New Member
    IT Engineer
    Tarragona
    389Coins
    WOW, I will try the program, thanks
