Showroom Blame73's 2DOF Seat Mover
Discussion in 'DIY Motion Simulator Projects' started by Blame73, Nov 20, 2014.
  1. Blame73
    Blame73 Well-Known Member
    8,304Coins
    I can try contacting them, even if jrks are now 2 years old and bought over ebay.
    Last time I've been offered a small discount on a replacement, but buying from them + shipping costs it would cost me more than buying somewhere else, even with the discount.
    I must fix it!
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    Bummer.......
  3. Nick Moxley
    17,056Coins
    Pololu Offer's 50% off in these situations...I find it hard to believe you can find a retailer that can match that price with shipping.
    Also So you've now had 2 jrk's fail ? Im going to venture and say there's something up if you've done in 2 of them.
  4. Blame73
    8,304Coins
    The other time I've been offered a 20% discount on a replacement, and it was pretty new, so I'm hardly having a 50% discount two years later.
    I don't know what to say... they're closed inside a box, no movements, no shaking... and it's an hardware problem. Maybe I'm just lucky...
    I made some progress, now it connects to the PC and sees the pot. Tomorrow I'll connect power and motor. Let's see, but I'm not confident: leds blink differently from the other jrk.
  5. Blame73
    8,304Coins
    Yeah! I menaged to fix the JRK :thumbs
    Since I was there I made a new box for electronics using and old PC PSU so that I'll be able to switch motors faster as soon as I get my new 60:1 guys
    and with the new harness belts
    I'm still unsure if keep the shoulder mount with the new motors or make the rig smaller movin them in front of the seat.
    Any advices?
  6. Nick Moxley
    17,056Coins
    what was the problem ?
  7. Blame73
    8,304Coins
    @Nick Moxley as for the other one, the mini usb connector was loose (I don't know if it's the right English word) and just by moving it a micron, it lost connection and didn't work anymore on the USB port it was connected to.
    152,093Coins
    +11,065 / 56 / -2
    I had one like that:
  9. Daguru
    Kitchen installer
    Wales uk
    461Coins
    Motion platform
    Hi @Blame73
    yes loose is a good english word to describe the fault you had :thumbs
    Looks like you new motors are the same as what I use look forward to seeing your rig in action with them :popcorn
  10. Blame73
    8,304Coins
    Yes, the same problem, mine once lost connection also didn't connect anymore (something like overcharging USB port), I see in your video yours turned green again (the LED)
    Did they replace it? Or you had a refund?
    152,093Coins
    +11,065 / 56 / -2
    It was replaced by the 3rd party supplier I got it from.
  12. Blame73
    8,304Coins
    Got back home... SURPRIIIIISE!! A box was waiting for me :D
    Ok, wiper motors look really tiny now!
    Now I just have figure out how to attach the levers...
    I was thinking about something like this (a shorter one) with a rose joint at the end of it:
    Any tips @Nick Moxley @noorbeast ?
  13. noorbeast
    152,093Coins
    +11,065 / 56 / -2
    For mine I was concerned about maintaining strength when the shaft had a 8mm hole in it.
    So I machined an interference fit tube which is quite thick and a step down has been machined at the gearbox end, just after the 8mm securing bolt, to be able to fit into the gearbox opening.
    It is hard to see because of the poor lighting, but here is a picture:
  14. Pit
    30,490Coins
    You could mount a bike crank as I did.
  15. RacingMat
    21,050Coins
    indeed!
    fedor_vs_choi-copy1.png oups, picture is not large enough :eek:
    but size doesn't always matter,
    maybe the small one will win over the big one?
    mmm, not sure
    :confused:
    • Funny Funny x 2
  16. Blame73
    8,304Coins
    Thanks @Pit, have you got a bigger picture of the shaft?
  17. Nick Moxley
    17,056Coins
    Love the motor's....Hate the Bolt/Level Idea. :grin
    I would look into Either Pits or Noor's fabricated solution.
    Being a seat mover, there isn't CRAZY high load forces on the motor's...but a solid solution is better than one that will fail in the future.
  18. Blame73
    8,304Coins
    Ok, I see what you've done. It's just I don't own a welding machine for the shaft
  19. Blame73
    8,304Coins
    I'm not so sure to keep the shoulder mount and you're right, I don't want a temporary solution
  20. Pit
    30,490Coins
    Are you drunken?:cheers
    Here you go
