2DOF compact seat mover
Discussion in 'DIY Motion Simulator Projects' started by pipis2015, Mar 14, 2015.
  1. Nick Moxley
    Where did you buy it from ? Most retailers who re sell these make it known that they were pulled from a "WORKING" server. Contact the seller.
  2. Blame73
    Blame73 Well-Known Member
    8,305Coins
    I bought both mine on the bay for very few €€€
  3. Knauba
    Knauba New Member
    143Coins
    2DOF, Arduino, JRK
    Bought mine from ebay too and contacted the seller. Thanks and sorry for hijacking the thread.
  4. FoxHound.92
    FoxHound.92 2DOF seat mover
    52Coins
    What is the battery for? To aid the system when turning it on?
    As that is a current plothole in trying to understand everything needed for starting my own build. :roll
  5. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    The power supply units as powerful as they might be, are purposed for use with computer circuits.
    So they are very sensitive to excessive changes in power draw conditions.
    This can cause their protection circuit to trip and shut them down.
    A battery can absorb power spikes and make life easier for the PSU.
  6. f1iceman
    - 87Coins
    Brilliant glad someone has done the whole thing I started this same thing last year on a spare set of pedals for t500rs.
    Will try find the pics as it's about the same where I was going too in fact it was exactly the same just about.
    I new you could wire direct as the sensors on my pedals should be 0v-5v which is sensor range. It was the sensor and shere fact it could be direct wired that i wanted to try on those pedals which was what triggers the whole thing I started it.
    But I lost interest in it as had other things going on.
    So glad you have completed it with full guide.
    I will be getting it all out again now ! Lol
    And yes this needs to be put as a sticky in the build section I think defo.
    Good job dude ! :)
  7. FoxHound.92
    52Coins
    Thank you for your fast reply!
    Does the battery need any kind of maintenance over time, e.g. charging or something like that?
  8. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    Where were you able to get the sheet of metal for the base ?
  9. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    Where were you able to get the sheet of metal for the base and how thick did you get?
  10. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,288Coins
    3.5 years since this build appeared and there's still a wealth of useful information & ideas here.
    Thanks for sharing your build.
    Pic's are worth 1000 words, and have helped give me ideas for my under-the-seat mover and components placement.
    Cheers!
