prilad
WRC: FIA World Rally Championship Plugin 2.0.0.1
SimTools game plugin for WRC3 and WRC4
  1. value1
    14,237Coins
    Patching WRC5 will only be possible, when we update the plugin to support WRC5.
    This is in the pipeline - though the pipeline is pretty clogged with all kinds of stuff and plugin updates.
  2. ffb.boy.30
    ffb.boy.30 New Member
    445Coins
    How works the plugin for WRC4 : memory hook like rollercoaster or memory sharing ?
    I don't understand what is the patch system for the game .
    Thanks you
    153,764Coins
    +11,149 / 57 / -2
    Best place to start is by reading the SimTools documentation: http://www.xsimulator.net/simtools-complete-documentation/
    Then if you are interested in how plugins function then read the plugin API tutorial: http://www.xsimulator.net/community/faq/how-to-write-a-plugin-for-simtools-api-documentation.131/
  4. ffb.boy.30
    445Coins
    I've already read the plugin API page , but if you don't know wich type of plugin I've to use for this game, Is there a list ?
    I will look at the simtools documentation ASAP.
    Thanks you
    153,764Coins
    +11,149 / 57 / -2
    No there is not a list, you need to research the game yourself.
  6. ffb.boy.30
    445Coins
    So for WRC4 what is the good way to make the plugin , is there a sample ?
    153,764Coins
    +11,149 / 57 / -2
  8. ffb.boy.30
    445Coins
    Yes for lot of game but WRC is not listed in the API , that whay I ask all this question , I don't find the good way to make it ...
    153,764Coins
    +11,149 / 57 / -2
    Those API examples are to show how you go about the process, there is not an example for every game, you need to do some research to figure what approach to use.
    You can use Google to see if a game has UDP, Memory Mapped Files or telemetry DLL. If you do a quick search on those for WRC4 and get nothing then that leaves the memory hook approach.
  10. ffb.boy.30
    445Coins
    I've been looking for few days without finding any solutions, that why I post here .
    So it is memory hook, So I've to find the table for all the data I need.
  11. ffb.boy.30
    445Coins
    Lot of stuff , I looking with cheat engine , I've found the gearbox but when I restart the game the pointer is lost .
    I think it will take a long time .
  12. dualclick76
    dualclick76 Active Member
    italia
    19Coins
    thanks for the work done. I installed the wrc4 Version 2 plugin for simtools 2 but there is no movement. thanks again.
  13. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    Saying it does not work is very little to go on.
    Please post some pictures of all of your settings.
  14. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    I was going to test this plugin today, so will post back my findings.
  15. Sarge
    - 181Coins
    Tested and found to be not working, however, the problem seems to be the same as what is posted back from when the plugin was released on an earlier version of simtools. Upon starting wrc4, this appears;
    I am using a boxed version of the game, which through reading earlier posts, was added to the earlier version of the plugin and fixed this problem.
  16. dualclick76
    italia
    19Coins
    153,764Coins
    +11,149 / 57 / -2
    Another for @value1's review list...he has beavering away at the post launch plugin bugs.
  18. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    WRC: FIA World Rally Championship Plugin 2.0.0.1 - SimTools game plugin for WRC3 and WRC4
  19. igor
    igor New Member
    179Coins
    Hello everyone. I am testing the World Rally Car 3 and 4 plugin and I can not get any of them. In the case of the World Rally Car 3 I can not make the simtool recognize me and on the other the World Rally Car 4 recognizes me but I can not get data to the game.
    Some help
  20. schubnel
    schubnel New Member
    france
    85Coins
    3DOF, SCN6
    hi, many thx for this plugin, is it possible to work with WRC 7 ?
    how can i have motion with WRC7 ?
    thx
