SMC3 tests work but simtools output test not, what am I doing wrong?
Discussion in 'SimTools compatible interfaces' started by xytras, Jan 28, 2017.
  1. xytras
    xytras Member Gold Contributor
    germany
    587Coins
    I know this problem came up shortly after I showed the proof of concept that the IMS-1 24V/20A H-Bridge driver boards work with SMC3
    https://www.xsimulator.net/communit...tor-driver-and-windows-utilities.4957/page-33
    But that thread got a bit out of control and lcturkey didn´t came to a solution there I think.
    Sadly it took me a long time until I was able to continue on the project so I am coming back to this pretty late :(
    Did anyone come to a solution with this ?
    Region shouldn´t be a problem as windows is installed in english?
  2. Pit
    30,490Coins
    Hi you did not set any interface output.
  3. xytras
    germany
    587Coins
    Haha sh... I wasn´t smart enough to read that from these lines:
    Setup for Simtools is very straight forward:
    [A<Axis1>][B<Axis2>][C<Axis3>]
    Set for 10bit binary output
    trying right now...
    EDIT: nope, that wasn´t the problem. TX LED on Arduino lights up but no movement with the sliders :-/
  4. xytras
    germany
    587Coins
    No luck, I also tried to put [A<Axis1>][B<Axis2>][C<Axis3>] in startup output and shutdown output but that doesn´t make a difference.
    I also tried to monitor the serial activity but that doesn´work because the port is busy with simtools :-/
  5. Pit
    30,490Coins
    If you are using SimTools 2 you have to set up as follows:
    [A<Axis1a>][B<Axis2a>][C<Axis3a>]
  6. Pit
    30,490Coins
    BTW SimTools and SMC3 cannot run at the same time.
  7. xytras
    germany
    587Coins
    Alright, thanks! This works. And yes I assumed SMC3 and Simtools don´t work together so I tried both ways before. But it was the "a" .
    Great, now I just need to wait for the 24V psu´s. Just found out that the 12V won´t lift me but at least my kids ;-)
    Get a wheel and pedals and build some frames that holds them.
    And of course a licence for simtools :D
    Once I got everything together I´ll post a long posting with materials and costs and of course some photos.
