Crammy's project No2
Discussion in 'DIY Motion Simulator Projects' started by crammy, May 20, 2016.
  1. stevemontuno
    stevemontuno Active Member
    1,461Coins
    It's starting to look like the dog's bollox dude :thumbs
  2. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    cheers mate. its turned out pretty smart i think. can't wait to get it set up now.
  3. GIB SimRacing
    GIB SimRacing Active Member
    Barossa Valley, SA
    983Coins
    Looking very nice indeed! You obviously don't waste any time getting it done. I'm looking forward to seeing that thing in action. Also, I should stop checking these thing out...makes me want to build another sim again
  4. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    thanks @GIB SimRacing . im going into work in a bit and bringing it home so i will have it finished next weekend hopefully. ill just be waiting for my pedals from HE and make the bracket for the handbrake.
  5. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    thought id take a quick mock up picture of how it looks. i've only rested the plates on and not fitted the actuators yet. i'm just clearing the room out and getting ready to start assembly. it should be finished on saturday. It was meant to be matt black but i picked up the wrong paint
    • Like Like x 5
  6. stevemontuno
    1,461Coins
    looks cool mate ,,,,,, lovin the ally checker , i might have to do my motor cover in the checker plate,,,,
    Also looks a lot smaller footprint in your house.
  7. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    I think the chequer plate stops it looking as diy and bodged as my first one. i've emptied the room now and the old rig is is bits. im off down the flooring shop at lunch tuesday as they are shut tomorrow to try and find some vinyl in the chequer plate style or something really dark.
    it has come out 1200 x 1050 and 350 high in the corners so not that big at all. the top frame over hangs at the front by 50mm.
    As you can see i've given up getting the house finished, much to the Mrs disgust lol.
  8. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    another mock up picture. ive just sat the seat on to see what it looks like.
    ill hopefully get a cobra seat or similar at some point but this will do for now
  9. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    i got the actuators mounted last night, and most of the panels. I am going to drill and tap the top plate though so i can remove it if needed. I will be housing all the cables in side for tidiness. It looked a mess previously. I'm going down the flooring shop at lunch to get a bit of vinyl before i put it in the room hopefully tonight then onto the wiring which wont take long at all.
    • Like Like x 6
  10. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    another quick update before i carry on. I manged to get some cheap vinyl flooring as they had an off cut in stock so just got that fitted. they had black and white chequered so would of been rude not to get it. i should be done in a couple of days hopefully ready for the weekend.
    • Like Like x 7
  11. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    realised i made a balls up on the top frame. the measurement i took before i made it from the old frame was 160mm under the seat to the floor. i actually dropped the wheel base 20mm on this frame, and not only did i forget to take 20mm of the seat base i forgot to take the 25mm off the cut length for the box section it is sitting on so now the seat is 45 mm higher to the wheel than it was before. ive now got to get it back to work and modify it. what a pain in the arse.
  12. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    well it is all up and running. i have just got to fix one of the side panels, fit the bushes for the underside of the top frame for the actuator ends to sit in which i will collect tomorrow, and adjust the wheel angle and that will do for now. i have another side panel to fit but this needs a hole cut in it for the cables. just waiting to get the pedals and handbrake and get them fitted also but i just want to use it now.
    • Winner Winner x 5
  13. SilentChill
    20,594Coins
    Looks great matey :) we will all have to get on AC together have some fun ;)
  14. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    cheers mate. i'll be up for that very soon
  15. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    Pedals and handbrake have just been ordered, so ill hopefully have them by tuesday. I can finally install simtools 2 over the weekend and get this set up properly.
    would never of had it all with out the help, support and advice from you guys on this forum.
  16. Pit
    30,497Coins
    @crammy congratulations to you, amazing work and craftsmanship. Just a quick note about the distance between the seat and the displays, I dunno if it's angle view related but it seems they are too far away from the seat.
  17. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    Thanks mate. im happy with hour it has turned out. The screens are to far away at the minute. I have got to make 2 new uprights, because at the moment the feet on them are stopping me from pulling them any closer to the wheel. i will order a length of 30mm box section next week. Ideally id like them about a foot from the wheel
  18. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    i just picked up my nylon inserts from the machine shop round the corner so i will get these fitted when home from work and with a bit of luck have a go tonight, (after ive tidied up the mess in the living area and picked up all the bits of metal from drilling and tapping lol).
    Also just had an e-mail from HE and my pedals and handbrake will be here on monday.
  19. stevemontuno
    1,461Coins
    You rig is looking mint mate ,,,very pro looking :thumbs
  20. crammy
    Fabrication
    essex
    4,633Coins
    SCN6, 4DOF
    Cheers mate. i will hopefully be having ago in a few hours:grin
