My DIY Cabinet Arcade - Raspberry
Discussion in 'Off Topic - All other stuff here' started by mirkobastianini, Feb 4, 2017.
  1. Bernd Manger
    Bernd Manger Active Member
    Measurement and control mechanic
    1,054Coins
    It would be a good idea to introduce your plans (perhaps with a drawing and a list of the planned hardware) in an own thread in "DIY Motion Simulator Projects".
  2. mirkobastianini
    mirkobastianini Active Member
    informatic
    italy
    1,300Coins
    Something like this is "seat mover", right? :)
  3. Bernd Manger
    1,054Coins
    You had the chance of 50 to 50, and ...... wrong.
    No, that's a compact frame mover. :)
    At a seat mover only the seat is moving, the name says it already. ;) The pedals and the steering wheel are fixed.
    You should lay your guitar aside and make your school tasks. Didn't your parents say it over and over again ? :grin
    By the way, i've finished my diy h-shifter (to see in my thread).
    And tadah....... my sim is also a seat mover.
  4. mirkobastianini
    informatic
    italy
    1,300Coins
    I'm here just to Learn, so it's normal that I might say something stupid... I've read FAQ in my spare time (the night, when I don't stay at work or when I'm not playing instrument or programming), but the world of simulator is very hard!
    Anyway, I want to make this simulator like passion, not work...little by little, i've already finished my model.
    Good job for your h...very impressive with Ard :)
  5. Bernd Manger
    1,054Coins
    Ok, i did not want to make jokes about you. I see you're serious about building a sim.
    The only way to find out all about sims is to read, read, read.
    I wish you all the best for your project.:thumbs
    151,461Coins
    +11,038 / 56 / -2
    What you want to aim for is maximising the design leverage available for any particular design.
    Mine started as a 2DOF and for a compact design I had a bit longer leverage length with front mounted motors, once I had found where the balance point was for my particular rig.
    I have extended the top connection bracket back to add the 3DOF for heave and run a longer lever tube on that motor. If I had done the 3DOF from the start I would have made the base 500x600mm, instead of the 500x500mm it is now.
  7. mirkobastianini
    informatic
    italy
    1,300Coins
    Thanks @noorbeast , and thanks @Bernd Manger,
    now i'm playing with this model, this is my first test...
    When I have some times, I will create new thread.
    In this simulation I have setting Roll (70%), Sway(70%), Surge(90%) and Heave (80%). Next step will be to put motors on front to see differences and make model more compact.
