2DOF mini Arduino motion platform protoype
Discussion in 'DIY Motion Simulator Projects' started by early_m, Feb 7, 2017.
  1. early_m
    early_m Active Member
    Chelmsford
    820Coins
    I've been playing with the idea of making a motion simulator ever since I played Project Cars on the Oculus Rift for the first time. The issue is I don't currently have the space to house one, not even a desk racer.
    So for now, I thought I'd make a mini one to learn the basics. 2DOF using some servos and an Arduino. I thought about keeping it simple, maybe build it out of Lego. Or simple MDF for mounting plates and platform. But in the end I wanted a proper little design project, so created a 3D model so I could get the parts 3D printed (Brother in-law works for Shapeways - free prints!)
    I've chosen the configuration shown in the video as it would appear that you achieve a better degree of movement of 'roll'. I notice many designs have the motors attached to the front corners, so the roll is achieved with some front pitch. Is there a disadvantage to my design by doing it the way I have when I scale up?
    I'm sure I'll require some assistance along the way. I've already found the forum incredibly helpful. Especially the posts from @eaorobbie.
    While I wait for my 3D prints to arrive I would like to hook my servos up to the Arduino and try out simtools. Learn out how to configure it using my design and get it working with PCars. Just need a pesky licence... 2DOF_0004_Flat.jpg 2DOF_0003_Pitch Forward.jpg 2DOF_0002_Pitch Backward.jpg 2DOF_0001_Roll Right.jpg 2DOF_0000_Roll Left.jpg
    Here is a link to a video of the platform in 'action'
  2. value1
    15,077Coins
    With your design, only the power of one motor is available to push/pull the platform for pitch and one for roll.
    If you add the motors to the "shoulders", you have the power of both motors to push forward (pitch) or roll sidewards (one pushing, one pulling).
    For your small scale modle, this is irrelevant I assume.
  3. early_m
    Chelmsford
    820Coins
    So will I have an issue if I scale up to full size? Is it a case of one motor for each not being powerful enough?
  4. early_m
    Chelmsford
    820Coins
    I would have added this to the original post, but can't find an 'edit' button for the life of me...
    152,595Coins
    +11,087 / 56 / -2
    Anything can be made to work but it is not really cost/mechanically efficient.
  6. value1
    15,077Coins
    Fully agree. Efficiency is a design principle ;)
  7. value1
    15,077Coins
    I copied your video into the first post. You'll have an edit button after a few posts. That's for anti-spam-reasons.
  8. early_m
    Chelmsford
    820Coins
    Can you explain why it isnt cost efficient? I can understand why it could texhnically be mechanically inefficient as @value1 mentioned, but wouldnt it cost the same as mounting any where else?
    I've seen commercial designs using the same set up, so a little confused
  9. value1
    15,077Coins
    Cost of the motors is proportional to their power.
  10. value1
    15,077Coins
    If you cannot control your motors nicely or one is faster than the other, you'll have for example an additional roll movement when pitching. There are also mechanical reasons for choosing your design.
  11. early_m
    Chelmsford
    820Coins
    Ahhh ok thanks, makes sense
  12. early_m
    Chelmsford
    820Coins
    So would you advise scrapping this setup in favour for a front corner mount setup if i went full scale? I guess theres a reason I havent seen many on here....
  13. noorbeast
    152,595Coins
    +11,087 / 56 / -2
    Two motors at the front or rear would be a more efficient full size design.
  14. pab61
    pab61 Member
    Adelaide
    638Coins
    So that tilting the rig forward and back uses two motors rather than one (while sideways tilting will still only use one)? Which I assume works because most rigs are longer than they are wide?
    Thanks, just making sure I understand the reasoning correctly.
    152,595Coins
    +11,087 / 56 / -2
    Two operate in conjunction for pitch and surge. With sway roll one motor goes down, assisted by your body weight and the other goes up.
  16. value1
    15,077Coins
    Even for roll and sway, both motors are engaged.
    Look at your fourth and fifth picture in post #1. To come from picture 4 to horizontal position one motor would push your body against gravity and the other motor would pull against gravity until you reach horizontal position. From there to picture 5 both motors have to break so that you stay in position 5 and don't fall too quickly or deeper.
  17. pab61
    pab61 Member
    Adelaide
    638Coins
    Of course, obvious, that makes sense, thanks.
  18. early_m
    Chelmsford
    820Coins
    Ok thanks for the guidence @noorbeast amd @value1. For now I will stick with the prototype design to learn simtools and coding but will look to change the design if I scale up. I just need the plugin for PCars to start learning. Cheeky question, but dont ask dont get. Any chance of some coins so I can download it? Its the only driving game I own so seems overkill to purchase the whole plugins package.
  19. early_m
    Chelmsford
    820Coins
    OK i'm confused. I've downloaded and installed simtools and was waiting to be granted a licence. But I loaded it up and its in demo mode. All I want to do is test that my servos work. Can I do that in 'demo' mode?
    Also, I'm struggling a little with the code side of things. I've followed the instructions from @eaorobbie but it loks like I have a different version of simtools. I tried loading in the preset but it says it's invalid. I have set them manually by opening the config file in notepad and manually copying them across. For the Arduino code, there's 2 INO files. Which one do I load up to the Arduino?
    I've searched the forums but can't seem to find any posts about my issues - am I being a dumbass?
  20. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
    you need a key to get out demo mode either a diy or pro key.for a diy key https://www.xsimulator.net/request-diy-key-simtools/ or buy a pro key from here https://simtools.us/license/
    here is how i managed to get my scaled model working https://www.xsimulator.net/community/threads/2dof-simulator-servo-model.6851/#post-77270
    SimTools 2.0 Input Settings - The difference from SimTools 1.3 to SimTools 2.0 in setup is that instead of axis defined like this <Axis1> it is now like this to designate grouping for a or b <Axis1a>
