2dof seatmover
Discussion in 'DIY Motion Simulator Projects' started by BruceBoc, Feb 7, 2017.
  1. BruceBoc
    BruceBoc Member Gold Contributor
    Technician
    120Coins
    Hello guy,
    This is my current seatmover, work in progress.
    It's a 2 dof with 120W DC motors and a sabertooth.
    The wheel is a G25.
    For the moment, i play on a old 720p TV, but a would like an oculus.
    152,409Coins
    +11,077 / 56 / -2
    I look forward to seeing your rig in action when you get the time for a video.
  3. BruceBoc
    Technician
    120Coins
    The video :
    152,409Coins
    +11,077 / 56 / -2
    Nice to see your rig in action :thumbs
    As your refine your motion profile you may want to add some more heave and surge, with the latter also configured for gear shift effects: https://www.xsimulator.net/community/faq/snappy-gear-change-motion.121/
    There is flex of the motors, particularly the one on the right. You will get even better motion if you fix that so there is none.
    I am looking forward to your next update.
  5. BruceBoc
    Technician
    120Coins
    Thanks for your advices.
    For the gear effect, i will configured it when i will receive de diy version 2 of simtools. I have send a mail but i still wait for it.
    For the flex of the motors, i initially posed a second square, but the cam is to long and stops in.
  6. BruceBoc
    Technician
    120Coins
    New video where we see the comparison of the support motor with 1 or 2 brackets. The difference in rigidity is blatant.
    Original G25 support directly put in seat support :
    Origin alim fan replace by a bigger Noctua who make less noise
    New real rally backseat :
  7. BruceBoc
    Technician
    120Coins
  8. BruceBoc
    Technician
    120Coins
  9. BruceBoc
    Technician
    120Coins
  10. BruceBoc
    Technician
    120Coins
  11. BruceBoc
    Technician
    120Coins
  12. creazyrider
    creazyrider Active Member
    france
    850Coins
    Hello Bruce,
    Nice simulator ! can you convert it in flight simulator too ?
    If yes do you have a picture in this configuration ?
  13. BruceBoc
    Technician
    120Coins
    Hello CreazyRider. When i want to play flight simulator, i just permute pedals, and i play with joystick on my legs.
  14. BruceBoc
    Technician
    120Coins
  15. BruceBoc
    Technician
    120Coins
  16. BruceBoc
    Technician
    120Coins
    Script to switch on 2nd screen and launch softwares :
    Code:
    @echo off
    C:\Windows\System32\DisplaySwitch.exe /external
    cd "C:\Program Files (x86)\SLIMax Manager Pro"
    start "" "SLIMaxMgrPro64.exe"
    cd "C:\Program Files (x86)\SimTools"
    start "" "SimTools_GameEngine.exe"
    start "" "SimTools_GameManager.exe"
    cd "C:\Program Files (x86)\opentrack"
    #start "" "opentrack.exe"
  17. BruceBoc
    Technician
    120Coins
    And the script to stop all :
    Code:
    C:\Windows\System32\DisplaySwitch.exe /internal
    taskkill /F /IM SLIMaxMgrPro64.exe
    taskkill /F /IM SimTools_GameManager.exe
    taskkill /F /IM SimTools_GameEngine.exe
    taskkill /F /IM HeliosControlCenter.exe
    taskkill /F /IM opentrack.exe
  18. creazyrider
    france
    850Coins
    What is the cap for ? head tracking, to turn the view ?
    could you put the picture again ? the 2nd one didn't work
  19. BruceBoc
    Technician
    120Coins
    Yes, it il head tracking, working with eye toy, but i don't really use it.
  20. BruceBoc
    Technician
    120Coins
    Complete overhaul of my simulator. Based on Simracing Rig S-Dream simulator based on Motedis profiles. I took the opportunity to change G25 to TS-XW racer.
