Please help with SimTools settings
Discussion in 'Commercial Simulators and Peripherie' started by TPS, Feb 9, 2017.
  1. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    OK - The new converters are put in place and all seems to work but the signal/movement is weak. So I must have put some low values, I guess.
    Here is the Game Engine.
    Should it be set to 60%?
    How many forces/DOFs should I define in this field?
    Why there is one box ticked in orange?
    Here is the first tab of GM
    Should I increase the speed and acceleration to much bigger values? Or should it be as it was stated in the manual?
    As far as this I think I figured it out well
    There is one additional force available in the tab MORE - which is traction loss
    Any help is much appreciated :)
  2. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    Still struggling - maybe because I am a philologist by trade, not engineer.
    I set all forces max - now it is time to tune it up. But I feel my axis are all mixed up. When I brake it drags me towards left. When I accelerate it drags me backwards right.
    How can I check if 2DOF with 100mm SCN at the back works the way it should without all these time consuming trials and errors?
    Maybe I am too stupid, but I would never ever say ST is very simple.
  3. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    I have sorted out, but still acceleration is weird. But I know more, fortunately I found manual from prosimu. It is more helpful than resources here.
  4. abs
    consultant
    Montreal
    774Coins
    3DOF, SCN5
    Hello I know you are exited with the new toy . You should first read the tutorials and do some testing to understand how it works. and yes simtools is easy (believe me i have used other software). the profile depends on the geometry of the harware you use (angles) and also personnal liking.
    advice : set your forces to minimum at first in the game engine (roll , pitch and surge to low value at first). Increase them slowly by 10 percent and check how it feels . this while the profiler has everything to the maximum or near the max.
    dont forget to set 90 percent travel maximum or bye bye those nice actuators. this will help preserve them ( I have mine since 2011 so i guess 90 percent helps)
    alos one axis for the roll has to be inverted do a test to figure out which one (use the virtual help tool)
    You can also check the virtual xxxx at the same time as the output testing see if both go the same way (it helps figuring if all is OK)
    and YES do some trial and error and see how all reacts.
    at this point you should have a fluid motion
    after that add some Heave and then also sway
    rgarding your adapter check the manufacurer spec sheet for the power +, gnd, white data +, and green data -
    if you swap green and white your actuator goes reverse so either you swap back or reverse the axis in game engine
    Power + is not needed current will come from the PSU, the ground (usually GND, black) is needed
    or buy devantech RS485-usb (all the wiring position is easy to find)
    or in europe : technofix.uk (FTDI USB to RS485 Converter for CCTV, EPOS, industrial control
    FT232RL & SP485) . they work nicely and the wiring is on their website
  5. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    Thank you for your input. From first test, according to this https://www.xsimulator.net/co-ordinate-system/
    my only issue is acceleration and braking. Turning left, right corresponds accordingly .
    I will post the pictures of axis and DOF (sway, surge, pitch, roll, etc) - maybe some of you spot my mistake. After the whole day of trials and errors I am tired, blind, and mad. But after investing money and time in Simtools, which were to be piece of cake I will figure it out.
  6. abs
    consultant
    Montreal
    774Coins
    3DOF, SCN5
    You probably have to revert the axis of surge and /or pitch. check both squares of both axis at the left in the game engine.
    you can confirm this with the virtual tool used at the same time as the outputesting. if the axis go at opposite direction. you have the answer
  7. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    Is the order of DOF# and surge, pitch, sway important ? Or in first DOF there might be heave?
  8. abs
    consultant
    Montreal
    774Coins
    3DOF, SCN5
    I dont believe it is that important . But i d rather go with roll first, pitch , surge a they are the main force in action (to me ) that determine quality of motion. heave and sway and yaw a bit less critical probably . yaw and /or extradata 1 will be usefull fully with a third actuator / motor for traction loss.
    these info are just personnal feelings/understandings. Maybe Yobuddy or one of the Gurus can give more accurate info on those forces
    151,467Coins
    +11,038 / 56 / -2
  10. Pit
    30,482Coins
  11. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
  12. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    Something is wrong with my SCN5s. According to what I believe should work , if I use output testing, using axis (not 2DOF), both my axis should activate actuators, should they?
    What I mean is - when I use slider 1 - right actuator moves accordingly. When I use axis 2 nothing happens
    Here is my definition of actuators in Interface settings
  13. noorbeast
    151,467Coins
    +11,038 / 56 / -2
    It would help if you post pictures of all of your settings, like you Interface settings and axis assignments.
    Output testing will only work with the Default profile, is that what you are using?
  14. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    Your question about interface setting confuses me as I already posted them. WHat else I can show as far as the INTERFACE tab?
    Here is Axis Management
    151,467Coins
    +11,038 / 56 / -2
  16. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    Your input is more than helpful, especially when I am on the edge to forget Simtools due to my frustration. Lince 1.4, very primitive works the way it should.
    But notwithstanding the DIR, my left SCN does not move, only right one
    151,467Coins
    +11,038 / 56 / -2
    What is the hardware setup for your SCNs, are you using RS485s?
  18. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    yes, and as I said before, with Lince 1.4 all works fine both AC and iR
    Motion Simulation Software SimTools
    151,467Coins
    +11,038 / 56 / -2
  20. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
