2 DOF (Little Red) Trial run
Discussion in 'DIY Motion Simulator Projects' started by RhaR, Feb 10, 2017.
  1. RhaR
    RhaR New Member
    USA
    - 29Coins
    After 4 months finding and making parts, finally I finish my first 2 DOF racing simulator. Right now I atesting each motion and fine tune simtools setting.
    152,409Coins
    +11,077 / 56 / -2
    Well done, great to hear of another project nearing completion :thumbs.
    I am looking forward to some further details and a video of your rig in action when you get the time.
  3. RhaR
    RhaR New Member
    USA
    - 29Coins
    This is the testing video.
    At first my racing seat always stuck on right side so I thought I set over the power limit. After changing the setting( limit 70 to 50), I still got the same result. It seems not a rotation angle problem. I guessed there was low power output from right side. However I do not have a current meter to check if the current output is correct, I just changed a spare mm shield on my system. Then it worked well. ( my mm shields are all china clone boards) The quality is really not good.
  4. Pit
    30,494Coins
    BTW you may check the ball joint which is very sluggish. Furthermore you could still tune your SimTools settings, I determine a lack of sway and heave.
  5. RhaR
    RhaR New Member
    USA
    - 29Coins
    I knew the the ball joint issue but still thinking how to fix it.
  6. MarkusB
    4,215Coins
    Congratulations to your running rig!
    What motors are you using? They look like the ones from MotionDynamics (12V / 200W) with the 25:1 gear box and hollow axis. Is this correct?
  7. RhaR
    RhaR New Member
    USA
    - 29Coins
    Should be similar. I bought them from pgsaw Canada on ebay, because my location is US. The ratio that I choose is 50:1.
    speed is 50-60 rpm.
