Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Thx for the very fast response and, of course, all the different profiles and settings will remain saved, I hope...
  2. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    Yes, every thing remains the same except the previous bugs :grin .
  3. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    I am not able to use the update, because it crashes. Installef though, but does not start
  4. obobo
    obobo Active Member
    1,323Coins
    That's wonderful you save me ... replying and downloading on the phone is not interresting withous rig usable if no connection in my campain
  5. speedy
    Alexandria , Egypt
    7,944Coins
    Do you have windows 10 ?
  6. TPS
    TPS Member
    Business coach
    Lodz/Poland
    439Coins
    2DOF, SCN5
    Yes, pro
  7. speedy
    Alexandria , Egypt
    7,944Coins
    OK just turn OFF the aggressive antivirus and RUN the installer as ADMIN ...
  8. stevemontuno
    stevemontuno Active Member
    1,461Coins
    Cheers for the update @yobuddy :thumbs ,,,,, is boundary just reversed now ,, say if i had heave boundary set to 75.1 i should change it to 24.9 for same effect with the v2.1 update .
  9. yobuddy
    51,224Coins
    Keep me posted on this, there is no reason the update should not start.
    There just isn't any big changes from the last version is all.
    Anyway, keep me posted.
  10. RaceRay
    Hamburg, Germany
    23,877Coins
  11. Shige Tanaka
    Shige Tanaka FREX Actuator Supplier http://www.frex.com/gp/ SimAxe Beta Tester Gold Contributor
    FREX
    Osaka Japan
    - 274Coins
    2DOF, 6DOF
    It seems SimToolsV2 can handle total 12 actuators by a and b setup. How to assign total 12 axis by Axis 1a, 2a... and Axis 1b, 2b ... together? Thank you.
  12. yobuddy
    51,224Coins
    SimTools 2.0 can support the math for up to 12 actuators, but you need an interface that supports 2 or more axes to be able to assign all 12 outputs.
    For instance the SCN driver only supports 1 can per interface at the moment.
    So with SCN's you can have up to 6 actuators.
  13. Shige Tanaka
    FREX
    Osaka Japan
    - 274Coins
    2DOF, 6DOF
    I think it is very attractive if two motion seats work same time to training driver and co-driver for real rally car driving. 4 axis each total 8 axis will be good at least. Please.
  14. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    Just connect the second motion sim to the signal output from the first simulator and they will run parallel. (I think) ;)
  15. Shige Tanaka
    FREX
    Osaka Japan
    - 274Coins
    2DOF, 6DOF
    I didn't aware that way.
    You opened the new door for me. [​IMG]
  16. Claudemir
    23Coins
    Hello Friend? I have a doubt!
    I am Gold contributor,
    Sim Tools 2.1 when 1 Year - SimTools 2.0 Edition
    $ 89.99
    Commercial Use Permitted Use
    Allowed public will I have to buy the correct key?
    Do these keys after 1 year expire, and will I have to pay for it again? Crash within 1 year program?
    I paying for the Sim tools 89.99 can I install on more than 1 computer?
    For each simulator will I have a key or will it serve the others?
    thank you!
    152,609Coins
    +11,087 / 56 / -2
    Gold membership is related to plugin access and the Xsimulator.net site, not SimTools licensing.
    Here are the SimTools 2 license options, only the Entertainment License is an annual fee: https://simtools.us/license/
    Yes you do need to license SimTools 2 for commercial use.
    If you are running an arcade of simulators you will need multiple licenses.
  18. Claudemir
    23Coins
    Good evening? Paying the key $ 89.99 will I have the definitive key with unlimited time? And can I still market? But for my client to enjoy the equipment with unlimited time will I have to buy a new key of the same value?
    152,609Coins
    +11,087 / 56 / -2
    There are 2 types of commercial license available via the link I previously posted.
    The first is for commercial simulators that are sold and SimTools is to be used, the second is for commercial use for rides, like in arcades, and that is the only one that needs to be renewed annually.
  20. yobuddy
    51,224Coins
    @Claudemir
    No.
    If you sell simulators, sell them with a pro license.
    If you sell rides on your sim, or rent them out, you need an entertainment license.
