My 2dof simulator project
Discussion in 'DIY Motion Simulator Projects' started by Juanjo1986, Jan 24, 2017.
  1. Juanjo1986
    Juanjo1986 Member
    Comerciante.. Copiloto Rally...
    Argentina
    489Coins
    In Pit's recommendation, I'm already preparing the coolers for each of the ibt-2
  2. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    thank you very much @dualclick76
  3. dualclick76
    dualclick76 Active Member
    italia
    1Coins
    very thorough job, but if I can afford I would recommend you to insert the tie rods for horizontal movement motor tl von links.jpg
  4. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    If I need to install the bar to block the rotation and some modification. I'm also going to put traction loss
  5. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Cabinet and finished house, a 60mm cooler is missing for the ibt-2 and the 120mm general extractor in the lid
  6. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Is it necessary to put the two bars to block the rotation? Or is it enough with only one?
  7. dualclick76
    italia
    1Coins
    preferably two
  8. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Once the cables have already been placed in their respective pins, I came up with a penerle heat shrink so they can be firmer and there is no danger that one of them coming out, the same as I did with the + and - signs of 5v
  9. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Here I show the box where all the electronics are
  10. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    One of the first test, it works, it makes me deny a little but walks ... I only need to modify the structure because the center of the movement I do not have it well under the armchair, because previously to move the whole structure and was a lot of weight. .. these days it is modified and it will be added more% of movement because it is short.
    Software 1.3
  11. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Not having the pivot well in the center of the armchair, I am loading weight (kg) to the engines and raise temperature
  12. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Modification of the structure and adding traction loss
  13. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Installation of the potentiometer on the opposite side of the shaft tip
    IMG_20170227_202000551.jpg IMG_20170227_202220785.jpg IMG_20170227_233553485.jpg IMG_20170228_020546310.jpg
    Pierce with 4.25mm wick and I made 5x0.80 thread
  14. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Finished the mechanical part. Just do some test posts see that everything is perfect
    IMG_20170227_233524233.jpg IMG_20170228_240754270.jpg IMG_20170228_010732922.jpg
    IMG_20170228_020404061.jpg IMG_20170228_020914896.jpg IMG_20170228_020928217.jpg
  15. Nick Moxley
    Nice progress, However I highly doubt those wiper's will be able to deal with that TL lever length you chose. I suggest smaller to start off with.
  16. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    Hi Nick, do you mean the traction loss lever?
  17. Nick Moxley
    Yes
  18. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    A little test of the modification to the structure, everything works perfect. Just need to configure a few more axes and profiles so that everything is fine and run the traction loss that at the moment does not work for me
  19. Nick Moxley
    What game are you playing ? Does it explicitly state it has TL in the plugin ?
  20. Juanjo1986
    Juanjo1986 Member
    Argentina
    489Coins
    I have been testing with Corsican, dirt rally, richar burns rally and LFS and none walks me.
    Now install the new version 2.01 of simtool and nothing works for me.
    Something else I have I assure you
    I was loading the plugins to SimTools_PluginUpdater and it tells me that it was installed correctly.
    Luiego in game manager and game engine I did not include the previously installed plugins
