Question 2 dof project
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by djaysam, Feb 17, 2017.
  1. djaysam
    djaysam djaysam
    pakistan
    266Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Joyrider, Motion platform, 4DOF
    hello every one
    I have started 2 Dof project
    1. I have Arduino
    2. monster shield
    3. 12 Volt PSU
    i am sharing my connection as i tried to see from this forums i want help
    i am sharing what i have did
    1. connected arduino with monster shield
    2. attached 12 volt Power supply with monster shield
    3. dc multi-meter for output testing from monster shield
    4. i have connected arduino with pc and it is showing in Com 5 ( Bit rate per second ) 115200
    now i don't know what to do please guide me
    Connection from monster shield are
    Ardiuno / motomonster
    4pin / 4 pin
    5pin / 5 pin
    6pin / 6 pin
    7pin / 7 pin
    8pin / 8 pin
    5v / 5v
    Gnd / Gnd
  2. Pit
    30,490Coins
    Hello, which Arduino sketch are you using? Also please have a look at our FAQ.
    152,003Coins
    +11,061 / 56 / -2
  4. djaysam
    djaysam djaysam
    pakistan
    266Coins
    hello i have done wiring from this diagram
  5. Pit
    30,490Coins
  6. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    Hi, which Arduino code are you using ?
    IS mandatory question ... every code/sketch will use a different wiring diagram and settings .
  7. djaysam
    djaysam djaysam
    pakistan
    266Coins
    SMC3.ino
    Now i have started following this link
    and change my connection
    am i going to right direction now ?
  8. Pit
    30,490Coins
    Yes, now you can start with the correct wiring.
  9. djaysam
    djaysam djaysam
    pakistan
    266Coins
    now i have open smc3
    and when i open smc3 utility i am having a error
    what is wrong
  10. insanegr
    insanegr !N$@n€
    Athens
    16,722Coins
    is your arduino connected to your PC?
    have you configured the right com port in SMC3Utils.ini ?
    if not open it with a text editor at put the com port your arduino is using
  11. Pit
    30,490Coins
    Before you make any tests you should read the SMC3 manual first.
  12. djaysam
    djaysam djaysam
    pakistan
    266Coins
    Thanks buddy smc3 utility is working now
  13. djaysam
    djaysam djaysam
    pakistan
    266Coins
    i got it
  14. djaysam
    djaysam djaysam
    pakistan
    266Coins
    now my motor is operating from the pot in both dimensions
    now what is the next step
  15. Pit
    30,490Coins
    Your screenshot tells me that your setup is not rightly configured. The motor should move until the ForceFeedback Line (green) is in the middle position.
  16. insanegr
    insanegr !N$@n€
    Athens
    16,722Coins
    connect the pot to the motor and follow these steps
  17. djaysam
    djaysam djaysam
    pakistan
    266Coins
    hello,
    I have tried to do by instruction but i don't think so its working out i can't find my mistake i also have changed the pot connection
  18. Pit
    30,490Coins
    Again check your potentiometer without motor, just turn the pot and look at the feedback line, ideally you upload a video.
  19. speedy
    Alexandria , Egypt
    7,943Coins
    @djaysam ... now go back to the last successful step you had when you was making the motor move in both direction by rotating the pot manually and making the green line move up or down by hand ...
    when @insanegr told you to connect the pot to the motor ... He meant to do that in a mechanical way ... so the motor shaft is mechanically rotating the pot shaft ... and they should both be matching in direction [that means the motor rotates to the same direction where the pot green feedback line goes ] otherwise you reverse the pot +ve and -ve connections ONLY ...
    This is pot 1 for motor 1 and the pot center wire remains in the same pot 1 connection in the Arduino .
    The final correct electromechanical connections gives you a good rectangle/triangle/ motion response exactly as the graph .
  20. speedy
    Alexandria , Egypt
    7,943Coins
    @djaysam ... What kind of POT do you use ?
