Tutorial SPS - Sabertooth Packet Serial PID motor driver sketch w/SoftStart
Discussion in 'SimTools compatible interfaces' started by BlazinH, Nov 10, 2016.
  1. BlazinH
    16,671Coins
    Clarification added to description.
  2. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,238Coins
    I plan on going with 2x60 Sabertooth, my only concern is the regenerative current flowing back to the power-supply, are the use of battery in parallel necessary with the 2x60 or we can use some Voltage Clamp Resistor? What are your guys recommending?
  3. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Sorry, I'd read all the thread and I can't find a fix for this. Any help? I can set up to 30, after that it goes to negative numbers.
  4. SilentChill
    20,596Coins
    Just type I the number and when it saves it goes blank it's how it's suppose to be ; (
  5. dong414
    dong414 New Member
    - 167Coins
    hi new member help have three point motion platform and two dimension sabretooth motor controllers with two kangaroos all tune up but I do not know how get them to run the three actuators on my flight simulator have been in touch with dimension but not much help would using xsimulator software help
    152,706Coins
    +11,092 / 56 / -2
    Arduinos are cheap, readily available and known to work...why would you not want to use one?
  7. Wagnard
    Wagnardsoft
    5,238Coins
    Hey guys, just to let you know that SMC3 got a new update yesterday and the 2 fixes would probably benefit this one too.
    Just saying...
  8. BlazinH
    16,671Coins
    No updates are really needed here. I fixed the min cut off bug when I modified the sketch so that's already done. And since sabertooth's aren't driven by pwm that issue is irrelevant considering the purpose of this sketch.
  9. evolaco
    evolaco Member
    Spain
    694Coins
    @RufusDufus Hello, to use a sabertooth 2X32 with SMC3 which steps should I follow? I read a lot but lately everything goes wrong and I do not know what to do, if I buy a bridge H expensive like this I want to be sure that I will not fail again
    152,706Coins
    +11,092 / 56 / -2
  11. BlazinH
    16,671Coins
    Since you posted on this thread I assume you're asking about the sketch you can download from this thread. If so then all you have to do is follow the steps in the first post.
  12. evolaco
    evolaco Member
    Spain
    694Coins
    And the resistors that are connected for what they serve?
  13. Pit
    30,499Coins
    AFAIK it's useful only when regenerative braking is used to turn the braking energy into electrical power (re- charging the batteries). Just disable it if you don't use batteries.
  14. evolaco
    evolaco Member
    Spain
    694Coins
    Simply do not connect the resistors? Or do you have to modify some of the Arduino code?
  15. BlazinH
    16,671Coins
    In short resistors are used to dissipate regenerative current when a battery is not used. If a battery is used then it will suck up regenerative current but without one it has nowhere to go except into your power supply or stay in your motors. However, if regenerative current doesn't trip your power supply then you may not need resistors but its a good idea to use them anyway because the they will help bleed off the extra heat created too. Either way though no code changes are necessary.
  16. matthew loomis
    matthew loomis Member
    rochester,ny
    603Coins
    I was just looking for a definite answer for this. So using the resistors is better than turning regen off with no battery?
    Edit found answer in describe section
    Disable Regenerative Braking
    This option disables regenerative braking. This is typically used to drive plating tanks, Peltiers or other loads that are not motors. A motor driven this way may run much less efficiently. Motors driven this way will also stop less rapidly. If you are running motors, but the system runs from a power supply, it is usually better to leave regeneration enabled and use the power outputs P1 or P2 as regenerative voltage clamps.
  17. evolaco
    evolaco Member
    Spain
    694Coins
    Can that be my problem with ibt2? I explain, as the motors move I increase the voltage of the power supply, from 13v goes up to more than 14v and gives a full turn to leave the range has risen to 19v and I stop the source and burn the vebtiladores of 12v cooling, I have put in a 40a diode in the positive of each ibt2, is it better to use resistors? Where and how should I connect them in the smc3 schema?
  18. evolaco
    evolaco Member
    Spain
    694Coins
    What resistances should I buy? If I do not put them there may be problems
  19. Blame73
    Blame73 Well-Known Member
    8,305Coins
    From what I'm reading, I think using a car battery (a bike one I my case) is always a better choice: it stores the extra power when braking not letting your psu just trip (that's a good and right thing) and it helps providing extra energy for the power peaks (that if your psu isn't strong enough would lead to a driver error)
  20. BlazinH
    16,671Coins
    I realize its easier to ask someone rather than to do your homework. But the answers to these questions are already answered in the first post of this thread had you bothered to read it thoroughly. So please start doing your homework first before asking questions so those creating threads don't have to continually repeat what has already been stated.
    Also FYI only the 2x32 can use resistors. If you have issues with regen current on a 2x60 and power supply then you must add a battery.
