value1
Project CARS Plugin 2.0.3.3
SimTools game plugin for Project CARS
  1. value1
    14,239Coins
    The plugin uses the shared memory structure of PCars, not the UDP interface.
  2. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    I feel like some of the axis are mixed up on this plugin. Surge for example for me on my saved template standard didn't work and I had to make adjustments.
  3. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    332Coins
    @value1 PCARS 2 currently has the ability to use the shared memory system of pcars1 for beta testing purposes.
    I currently i need PCARS1 shared memory for my AccuForce to work.
    My question is:
    - Is it possible to use the PCARS1 plug-in to get data from Pcars2 using the old (pcars1) shared memory?
  4. value1
    14,239Coins
    Why don't you use the pCARS2 plugin?
  5. HoiHman
    Mechanic
    The Netherlands
    332Coins
    I need the plugin for sim wind
    If i'm correct the pcars2 plugin uses the new shared memory which is currently not supported by my accufore yet. As long as the game is in beta testing we're also able to select the older pcars1 shared memory output. This works with my accuforce. So i thats why need the pcars1 plugin
  6. value1
    14,239Coins
    Too much speculation! Just try it
  7. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,945Coins
    Is the new SimTools 2 version of the PCars plugin the Shared Memory version only, or is there still a working UDP version? My PCars was bought through the Oculus Store so I'm not having much luck with the Shared Memory version.
    153,866Coins
    +11,154 / 57 / -2
  9. Spit40
    Spit40 VR Flyer
    United Kingdom
    2,945Coins
    Perfect !! Thanks
  10. Miguel Angel Luque Galvez
    Miguel Angel Luque Galvez New Member
    - 46Coins
    Hello. Sorry but i'm having a problem.
    I was trying this plugin with simtools 1.3 that I downloaded from this forum and with 2.1. But the "plugin installer" doesn't install it in the game manager.
    I see that there is differents .dll. It Works with ...Plugin.dll but doesn't work with ...GamePlugin.Dll. It doesn't install it.
    Thanks in advance.
  11. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,056Coins
    Arduino, 4DOF
    Do not mix 1.3 and 2.0
    Remove/clean everything and strart again, using only v2 simtools and plugin.
  12. Miguel Angel Luque Galvez
    - 46Coins
    Yes! I removed 1.3 and installed 2.1. But the plugin installer doesn't work with old plugins and with new plugins. It needed to buy the license or I can try it with the demo of 2.1?
  13. noorbeast
    153,866Coins
    +11,154 / 57 / -2
    Yes you need a license to use plugins with 2.1, though it does have a fully functional Live For Speed plugin pre-installed for testing purposes.
  14. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    You should double-check that the plugins directory is empty. Uninstalling may not be enough.
  15. john thornewill
    john thornewill New Member
    232Coins
    DC motor
    Hiya!
    I've got the general plugin working great with pCars, but when I try and use Extra1 for traction loss, the only values I get are 0 or 65535 which just flips from one value to the next depending on if I'm turning left or right??? I'm sure I'm being a dummy, but what am I doing wrong?
    John
  16. Nick Moxley
    Monitor the Tuning center values in Extra 1 2 and 3 and determine which is a slowly building data point like TL is supposed to be. I thought TL was Extra 1, but honestly dont know if thats still the case or not with V2.
  17. john thornewill
    232Coins
    DC motor
    Thanks for the reply Nick!
    I've checked out the tuning centre and I can see values for Extra 1 of +/- 14.134 which is interesting as I'm still seeing raw values across the interface of 0 or 65535.
    I'm sure I'm doing some newbie sort of mistake here, but I don't see how the floating point values in the tuning centre turn into integer values on the actual interface...
    Any help is really appreciated!
    John
  18. sixsimu
    sixsimu New Member
    287Coins
    I switch YES mmf in PCars but my sim still don´t move? Any idea? Thanks!
    153,866Coins
    +11,154 / 57 / -2
    More information is needed, can you please post pictures of all of your settings.
  20. sixsimu
    sixsimu New Member
    287Coins
    Ok @noorbeast , I take this pictures. I do not know if they will be enough, I hope your comment. Thanks a lot!
