RC Model for Motion Simulation
Discussion in 'SimTools compatible interfaces' started by eaorobbie, Jul 17, 2013.
  1. pillowsack
    pillowsack New Member Gold Contributor
    Programmer
    Vancouver, WA, USA
    371Coins
    Sorry, I had two tabs open and inadvertently posted twice. Found the issue FYI. I'll keep my posts to my thread.
  2. Schopfer
    Schopfer Member
    Thailand
    86Coins
    Hello.
    I uploade RCModelSimToolsMode.ino to Arduino Uno R3 and wired the servo as yours Picture
    RC Model Test_InterfaceConfig.cfg can't drag in Preset box. It show "RC Model Test_InterfaceConfig.cfg is not a valid Simtools preset file!
    152,541Coins
    +11,085 / 56 / -2
    Are you using SimTools 2, if so there is a change to the Interface Settings, so instead of Axis1 is is Axis1a and so on for each of the Axis.
    It would help if you post pictures of all of your settings.
  4. Schopfer
    Schopfer Member
    Thailand
    86Coins
    152,541Coins
    +11,085 / 56 / -2
    Try Decimal instead of Binary in the Interface Settings @Schopfer.
  6. Schopfer
    Schopfer Member
    Thailand
    86Coins
  7. Schopfer
    Schopfer Member
    Thailand
    86Coins
    I has a new question RC model is run in output testing mode but it not run on LFS Game.
      627 KB
      987
    152,541Coins
    +11,085 / 56 / -2
    That could be a couple of different configuration issues.
    First, it is important the LFS is run for a lap or two in normal game mode before patching. If you did not do that then unpatch LFS, run a lap or two the re-patch.
    You also need to create and Axis Allocation, I am presuming you have done so hence can you please post picture of all of your settings.
  9. Schopfer
    Schopfer Member
    Thailand
    86Coins
    OK I reinstall and run 3 lap befor patching. It's work.
    Thank you.
      610.4 KB
      1,103
      516.5 KB
      1,105
  10. insomagent
    insomagent New Member
    124Coins
    To anybody who can't seem to get the Output test working, try closing every related application (including SimTools and Arduino IDE), unplugging the Arduino, making sure that the correct sketch is uploaded, then relaunch SimTools. Without launching Arduino IDE. Everything worked once I did that.
  11. Taimur khan
    Taimur khan New Member
    Pakistan
    100Coins
    can we run 2 SG90 9g servos on the arduino 5v without any external power source?
  12. Taimur khan
    Pakistan
    100Coins
    i have configured the simtools 2 according to the settings given here ~R<Axis1a>~L<Axis2b> and Roll, Pitch to 60 but when i test the output on DOF then only one servo is making movement.
  13. noorbeast
    152,541Coins
    +11,085 / 56 / -2
  14. Taimur khan
    Pakistan
    100Coins
  15. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
    I just grabbed a few servos from a local hobby shop for this project.
    Will this work with the demo version of Simtools?
  16. noorbeast
    152,541Coins
    +11,085 / 56 / -2
    @Taimur khan there looks to be an unwanted space in your Interface Settings:
    152,541Coins
    +11,085 / 56 / -2
    Yes they will work with the demo version of SimTools using Live For Speed, as the LFS plugin is provided specifically for testing purposes.
  18. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
    Got it working. Now to throw a platform together.
  19. Taimur khan
    Pakistan
    100Coins
    Thank you very much i guess the servo movement is now correct.
  20. lizwqd
    lizwqd New Member
    Beijing
    52Coins
    我是新手,我已经购买了simtools和race07游戏插件,我使用RC_Sim_Model ino,并且正确接线,运行游戏,但我对电机没有任何反应,我不知道问题出在哪里是,请求帮助,谢谢
