Microsoft.net framework crash
Discussion in 'SimTools DIY Version' started by Vitalik, Feb 22, 2017.
  1. Vitalik
    Vitalik New Member
    Ukraine
    263Coins
    2DOF, 3DOF, Arduino, 4DOF, 6DOF
    Friends, help me find a mistake in the 2dof.
    I do as directed by the instructions, but when I run SimTools signal to the motor does not go.
    My print settings screens SimTools:
  2. Vitalik
    Vitalik New Member
    Ukraine
    263Coins
    I start the engine test - the engine is not running.
    include tests -Engine does not rotate (
    I used this code to Arduino:
    2DOF_Racingmat_Arduino_Code_and_Presets.zip
    So I connected:
    Arduino /..Motomonster
    ....GND <-> GND pin
    .........5V <-> 5V
    .....pin 4 <-> pin 4 inA motor1
    .....pin 5 <-> pin 5 pwm1
    .....pin 6 <-> pin 6 pwm2
    .....pin 7 <-> pin 7 inA motor2
    .....pin 8 <-> pin 8 inB motor1
    .....pin 9 <-> pin 9 inB motor2
    .....pinA0 <-> center pin of pot 1
    .....pinA1 <-> center pin of pot 2
    .....pinGND <-> 0 ohm's pin potentiometer 1 & 2
    .....pin 5V <-> 10k ohm's pin potentiometer 1 & 2
    Please tell me what I'm doing wrong?
    EDIT by Pit: please do not upload any Arduino sketch to any of your postings, thank you.
  3. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Hi.
    Test in Interface - Output L<Axis1a>R<Axis2a>
  4. Vitalik
    Vitalik New Member
    Ukraine
    263Coins
    thanks) test run - the motor is running!
  5. Vitalik
    Vitalik New Member
    Ukraine
    263Coins
    I launch the game (LFS), I see the error (
  6. Pit
    30,510Coins
    Thread title edited and moved.
  7. yobuddy
    51,523Coins
    LFS does not read or write from a process memory thou?
    Can you please click details so we can see a bit more?
  8. Vitalik
    Vitalik New Member
    Ukraine
    263Coins
    Thanks for the help.
    Code:
    Error:
    System.ComponentModel.Win32Exception (0x80004005): Запрос ReadProcessMemory или WriteProcessMemory был выполнен только частично
      at System.Diagnostics.NtProcessManager.GetModuleInfos(Int32 processId, Boolean firstModuleOnly)
      at System.Diagnostics.ProcessManager.GetModuleInfos(Int32 processId)
      at System.Diagnostics.Process.get_Modules()
      at SimTools_GameManager.frmMain.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
      at System.Windows.Forms.Timer.OnTick(EventArgs e)
      at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    mscorlib
      Assembly Version: 4.0.0.0
      Win32 Version: 4.6.1055.0 built by: NETFXREL2
      Assembly Version: 0.2.1.0
      Win32 Version: 0.2.1.0
      CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    xdFZySjlJvJuSyJCrKNFqiOVuiS
      Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
      Assembly Version: 10.0.0.0
      Win32 Version: 14.6.1055.0 built by: NETFXREL2
      CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
      CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
      CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
      CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
      CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
      CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
      CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
      CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Game_PluginAPI
      Assembly Version: 1.0.0.0
      Win32 Version: 1.0.0.0
      CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Game_PluginAPI.DLL
    System.Management
      CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    LiveForSpeed_GamePlugin
      Assembly Version: 2.0.0.0
      Win32 Version: 2.0.0.0
      CodeBase: file:///C:/Users/Oculus/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    Microsoft.GeneratedCode
    enabled.
    For example:
    <configuration>
    </configuration>
