My first 2of simulatord project )
Discussion in 'DIY Motion Simulator Projects' started by Vitalik, Feb 26, 2017.
  1. Vitalik
    Vitalik New Member
    Ukraine
    260Coins
    2DOF, 3DOF, Arduino, 4DOF, 6DOF
    Hello. I built my first 2of simulatord. 3 weeks ushle. There were many problems. but helped me on the forum. When examined, it turned out to be very simple))
    First you take the Arduino Uno - 1 piece, Monster Moto - 2 pcs, Resistors 10K (0,25-1 W) - 2 pcs, 12v engine - 2 pcs.
  2. Vitalik
    Vitalik New Member
    Ukraine
    260Coins
    This is the right plan! Collect the items exactly as indicated in the diagram.
    I got this:
    at each other I soldered:
    151,480Coins
    +11,041 / 56 / -2
    I am looking forward to seeing some pictures and hopefully a video of your rig in action.
  4. Vitalik
    Vitalik New Member
    Ukraine
    260Coins
    Next you need to install and configure Sim Toolse - this Russian version of the instructions.
  5. Vitalik
    Vitalik New Member
    Ukraine
    260Coins
  6. Vitalik
    Vitalik New Member
    Ukraine
    260Coins
    After setting up Sim Tools I had an error:
    is not correct: L<Axis1>R<Axis2>
    correct: L<Axis1a>R<Axis2a> 10 ms (at 20 ms - does not work)
    be sure to set up as in the picture:
    Turning on the power circuit to the motor, then we click - Output Testing - Turn On.
    Motors are to engines.
    Now I take off video!!!
    Be sure to check the connected equipment:
  7. Vitalik
    Vitalik New Member
    Ukraine
    260Coins
    If you run a test in the Sim Tulls and the engine is not running, then:
    1) you need to close the Game Manager and Game Engine
    2) disconnect the USB (Arduino Uno)
    3) Insert USB (Arduino Uno)
    4) initially run Game Engine, and then the Game Manager
    5) open the tab and enter data, or select from a list of saved,
    and be sure to press after each "Save" button.
    Then open this tab, click on "Turn On" (testing engines):
    If all is well, then you will see the light "yellow LED" on the Arduino Uno board:
  8. Vitalik
    Vitalik New Member
    Ukraine
    260Coins
  9. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Put some heatsinks on that motomonster
  10. Vitalik
    Vitalik New Member
    Ukraine
    260Coins
    radiators be sure to put motomonster )
  11. dualclick76
    dualclick76 Active Member
    italia
    11Coins
    in addition to the heat sinks must also put a nice fan because you risk frying
  12. dualclick76
    italia
    11Coins
    Another tip is if you allow the use of potentiometers, hall effect because more resistant precise, without block ...... but more expensive.
  13. Vitalik
    Vitalik New Member
    Ukraine
    260Coins
    OK, now I buy radiators.
    cooler with a computer will think is normal!
    while using a cheap resistor. And what is better?
  14. Andrew Eccles
    Andrew Eccles aceinnz Gold Contributor
    New Zealand
    - 541Coins
    Don't forget to put great big heatsinks on those motomoster chips. I used the exact same wiper motors. They both got very hot - the motors and the chips.
